rockcrawler
I’m in the process of installing two 24K mini splits in my shop. I want to run the lines inside the shop down to about a foot or so from the ground and then go out to the outside units. This will require me to cut a 3.5” hole in the middle of my 8” wall purlins. I just wanted to get some opinions on whether or not this will cause any issues. If so, can I weld in some kind of plate that will supply some support? I’m sure I’m wrong, but it almost seems that the wall purlins are holding the sheathing on more than anything.
These are the locations where I need to run the AC lines through the purlins. The inside units will be mounted just above that upper purlin. (Pic is from back when it was being built a couple of years ago.)
