Marctrees
Need to cut rectangular holes in about 24Ga Stainless sheet.
About 2" x 7", radiused corners OK.
The final hole needs to look nice, not necessarily PERFECT, but it will not be hidden in any way.
Needs to look as close to "factory" made as possible.
But ------------ not in a flat piece.
Picture in your mind - You go to Big Box and buy a typical Stainless sink that mounts old style manner w the rim flange sitting on top of your countertop.
And you want to cutout this hole in like an "overflow" position, near the mounting flange.
So, that flange sticking "up" when you're making the hole, is kinda in the way of some tools.
Best I can figure so far, a Unibit for the 4 corners, sabre saw for straights, cleanup w 5" pneumatic disc sander, and ?something? smaller to clean up the 2" cuts.
BUT even with patience, going slow, I know, if I did quantity's, they would not all be visually acceptable.
I MAY need to do this just once , but I'm posting BECAUSE very possibly hundreds of times, so need efficient methods.
Thank you all, Marc
Thank you all, Marc
