Cutting in an old work box
SethB
Need to cut in an old work box into a tiled wall. Never attempted that before. I'm thinking use my milwaukee OMT to do it, but not sure what blade is best? Diamond grit, Carbide grit? which brand is best?
Jim greengo
Behind my house
It might be easier to pop off the piece of tile and cut it,or just cut a new piece to to put back in its place.
Cutting tile on a wall *****.
rlitman
Long Island
What sort of tile. Porcelain? Good luck. Ceramic can have a tough surface, but cut like butter once you've broken through. I've used a similar diamond blade, and it wasn't that bad.
Also, it might make sense to drill the corners first.
Can you line the box up on the edge, or better yet corner of a tile, so you're cutting grout lines?
i wouldnt cut it on wall. could pop the tile out or grout. easier to remove tile and cut elsewhere. also easier clean up....
tab2
Boston
Backsplash? It is probably ceramic so it will start slow, but will get easier once you're through the surface. A multi-tool or Dremel with the correct blade will work. If is all about the blades.
That grout cutting one is terrible.
It will be annoyingly loud
sparky 1971
Central Iowa
I've done it a few times with a diamond grit blade in my M12 multi tool. It wasn't fun and took forever. Not sure how much of it was the gutless tool and how much was the tile. I now have a corded Rockwell that blows the M12 away, but haven't had to cut a tile with it yet.
Mr_fixit
Rustylvania
Dremel is what I used, with a reinforced abrasive blade. Cut a 4" round hole in a ~4 inch square tile.
I'd cut a 2 gang hole, maybe.
nadogail
Coronado, CA
When I have removed Kitchen Sinks in tile countertops I have found that the Carbide tipped blades in my oscillating tool cut the tiles like a hot knife cuts warm butter.
exranger06
CT
I used a Dremel with the 562 tile cutting bit once before. It worked very well.
rlitman
Long Island
They make a solid carbide version of that bit that's actually a really useful tool (I'm not in to HSS for that use). Look for the 570. I most often use it with a drill for cleaning tire punctures before plugging, but it'll cut tile too. Carbide can be brittle, so do be careful, but used with care, it will way outlast the HSS version. I sometimes use mine in a turbine grinder up to 65kRPM. Speeds that would trash the HSS bit.
SethB
So here's how it went:
Drilled corners with tile bit, then cut out tile. Took 2 diamond blades and a 3.0 and a 4.0 battery on my Milwaukee OMT, non-fuel. Dusty as hell and LOUD. Ran the shop vac and wore hearing pro.
Not a fun job, but all done
