Cutting Laminate
Bdgjr215
Tablesaw ,klenk cutters,router, depends on what part of the process you're talking about.
JR 42
Sunny Seattle
Scoring cutter, or hand shear, or router bit, or strip cutter, depending on what you're trying to do. I've never been thrilled with running a big, thin, floppy, brittle sheet through a table saw; it seems like more trouble than it's worth.
JR
Empty Pockets
Rural New York
When I was in the formica shop, we used a table saw with a plywood blade for straight cuts.
For cutting for an "L" shaped top, we would offset the laminate by about 1 1/2 inches, and trim it with a router, after edging the top.
Once the laminate was applied we would trim it with a router.
In every case, when using the router, use a bit with a bearing guide.
Empty Pockets
Rural New York
JR
Once you've done it a few times, it's easy, as long as you have room to work
