bobj49f2
I have project that I need two pieces of 1-1/4", 1/16" wall C-channel, six feet long. I can't find the correct C-channel I need but I can get 1-1/4"x1-1/4", 1/16" square tubing. It would work perfectly if I cut one side out of it.
I could use my plasma cutter but I'd have to make a fixture to hold the plasma cutter steady and then run the length of the tube making a two cuts. Then I'd end up with two jagged edges that I'd have to grind smooth. Also, when cutting into a tube with a plasma cutter it make a really sooty mess inside.
I was thinking I could use a metal cutting blade in my table saw. Not an abrasive blade like used in a cut off saw, but a metal cutting blade for a circular saw. I've used one in my circular saw to cut 1/4' angle iron and it worked really nice and didn't seem to produce hardly any sparks. I've used my table saw numerous times to cut aluminum up to 1/4" thick. I figure if I use the fence on the table saw I'd get a pretty decent straight cut that wouldn't need much dressing with a grinder.
Has anyone used a metal blade on a table saw to cut metal? The major concern I have is possible kick back but I think there is less chance of that with the metal cutting blade because it doesn't have the aggressive teeth that a wood cutting blade has.
