stonesfan68
I recently purchased a grinder that has damaged threads on one side of the shaft. The threads are left-handed. I think that the previous owner tried to remove the nut by turning it to the left instead of the right. I managed to get the nut off with a nut buster. As you can see the threads are pretty buggered.
I am relatively certain that a traditional thread chaser will not fix these threads and that I am going to have to cut new threads. The current threads are 1/2 - 20 UNF.
If I purchase a 7/16-20 UNF left-hand thread die can I simply cut new threads over the old? If so, does anyone have any tips as to how to get the die started? I've seen some dies that are adjustable, are those easier to use? The most I've ever done with threads is use a thread file and a thread chaser.
Do the threads really have to be left-handed?
Thanks in advance for the help.
Geeze, to chase or even cut threads there has to be something there to cut into. I'd go for the spacer route.
