Cutting oil
Fretters
South Yorkshire, England
While cheap, they aren't quite what I have in mind. I may have to hit a hobby shop for valves used in RC airplanes, or a good pet store that has brass valves for aquariums. I really would prefer brass in this situation.
Look for old air, fuel or gas taps. Fuel petcocks are another option too, from the likes of motorbike fuel tanks.
Douglas527
South Central PA
Anchorlube G-771 is a green lube that is the consistency of pudding that works very well for drilling and cutting in general. It is environmentally friendly as it contains no oil. You can get a free sample from thier website http://www.anchorlube.com/
Another good oil is Ultra Lube Metal Cutting Lubricant, Fastenal #0301864. it is the consistency of honey and will not smoke, but metal chips stick to it and it's kind of hard to remove from the surface.
Gert
Netherlands
Is kroon olie duur?
= "Is kroon oil expensive ?"
Hi Seinmetz, I paid something like 6 euro ($8,34) for a 500 ml (~0,132 gallons) bottle. Not really for free, but when using a small brush to add the oil you can do a long time with it. I think it's worth the money. :thumbup:
Rickedstyles
Conroe, TX
The shops Ive worked at use tap magic and Mike-o-cut tap magic I use mainly at home..Mike-o-cut is the best for when trying to get that one last hole out of a tap or drill..but sticky and messy..probably really only needed in machine shop..using some kind of fluid will really make a difference in tool life and make nicer holes/threads.. A can of tap magic that will last a long time for the avg person can be had for under 10 bucks
gyromike
Maurice, La.
I like to use this:
sberry
Brethren, Michigan
I need a new can of Tap Magic or Rapid tap mostly used fo0r threading and occasionally for drill or holesaw. Most steel I do by hand and dry. My helper uses a drill press on occasion but I cant remember the last time I did. I like vise or clamp to the bench, so easy to flip pieces around.
I am not much of a machinist and beat the snot out of bits but,,,, its fast, its super simple, portable.
mucksavage
Turnersville, NJ
I was recent on a job with ironworkers. They were drilling some holes in the bridge steel & were spraying Windex on the bit. I kinda chuckled and said "no cutting oil, huh?" He swore that it worked better than oil & that a lot of ironworkers use it
uart
Australia
... were drilling some holes in the bridge steel & were spraying Windex on the bit." He swore that it worked better than oil & that a lot of ironworkers use it
I wonder if his wife was at home cleaning the windows with tapmagic? :headscrat
Windex is only a low conc ammonia solution. You'd think straight water would work just as well to cool it.
BTW. Last time I looked at buying cutting fluid around here they wanted $17.50 for 250 mL :wtf: http://www.bunnings.com.au/sutton-250ml-cutting-fluid_p6320395
Hmm, used ATF and with a dash of kerosene costs me close to nothing and seems to work just fine. :)
onewaydave
Down the road from Dorothy and Toto
Humm. Not long ago I posted an question about the use of lard. I kinda got flamed for it. Boiled down to why use it with so many new high tech products out there.
I was basically interested in the history of the use of lard. Whatever.
I have also asked about the use of hydraulic fluid (I had 5 gallons that was contaminated with water and wouldn't trust it for use as hydraulic fluid) and was informed that it would not be a good cutting fluid as there was not enough sulfur in it. I thought HF and ATF were close relatives. Maybe not.
When sharpening a knife on a stone, use of water or oil "floats" the swarf away preventing the swarf from cloging the poors of the stone. Wouldn't this also be the case in drilling or cutting?
Dave.
