How do you cut polyiso insulation? I tried cutting one side with a razor knife and braking it like with sheetrock but it doesn't give a clean cut. It is 3 1/2" thick so my circular saw doesn't make it either. Any ideas? Thanks
Grind the teeth off of a jigsaw blade and use it like you normally would. I just did this for the first time a couple weeks ago and it worked great! No mess either!
Steak knife, or bigger kitchen knife for 3.5"
My brother made a hot wire tool which he used to cut foam parabolic reflectors for two up-firing speakers he built.
https://www.google.com/search?clien...+insulation+with+a+hot+wire&ie=UTF-8&oe=UTF-8
Has anyone tried a band saw? Not there yet but that's what I'm planning on using.
The jig saw blades work great and without a mess.
I am going to have to cut about 300 pcs of this stuff so a slow jigsaw type would take forever. This stuff has a tar like paper on each side so I don't think the hot knife would work. A circular saw is probably the best way to go but it is 3 1/2" thick so would have to cut from both sides.
