Cutting pvc conduit without damaging wire inside
PoorOwner
CA
I need to put in a bigger junction box.
3/4 pvc conduit 6 thhn inside
I heard you can use a copper tubing cutter to cut it instead of pvc scissors. Will that work?
snod83
Use a piece of nylon rope / string with two handles. It will cut right through it.
The Cobbler
there are tubing cutters with a larger flange on the cutting wheel for plastic pipe . or use a regular cutter and cut as deep as you can, then a oscillating tool or hacksaw for the last bit ,
I assume you're disconnecting the wires , form or get a pc of metal that slips over them and inside of the current conduit to act as a shield
alfredeneuman
Fullerton, CA
A piece of nylon mason's string will cut through without damage to the conductors.
It's flexible so can be used to work around the diameter , and leave the conductors intact.
P
PoorOwner
CA
I think I will try the copper cutter to score as much as I can, then try to snap it or finish with the PVC scissors, I tried to spin the scissors around but the cut is always crooked, with the score around it may work better until I can carefully snap it apart.
Bert_
NW Iowa
The scissor cutters can be used. Cut just far enough to get though the wall then spin the cutter around. A hacksaw works good too.
rharman
SoCal
This for the scissor cutters works. I've also used a regular old tubing cutter.
WasteNot
Careful! mason’s string WILL cut through the sheathing of most cables. THHN or comparable wire used in all residential buildings can’t hold up to a nylon string saw. I’ve made a fair amount of money in the past fixing burned wires that arched. IF you are careful, this can work well. Just remember to do this in 5 cuts around the pipe. My preference, if space allowed was a standard pipe cutter. Run it all the way around and snap then pipe. Use 1/2 of a piece of copper pipe slid into the pipe to protect the wires as I cut the pvc conduit lengthwise w/a grinder. I found these easier to use than an oscillating saw. Hope this helps for future projects.
driftpin
I've used a piece of monofilament fishing line to cut PVC, but never with energized leads inside. I just wrap it 360 degrees-past itself, and carefully saw-away. Some careful dressing of the inside cut, to eliminate an edge on the cut-line area of the PVC, is advised. Maybe a piece of sandpaper in a cylindrical fashion and a slightly-smaller inside diameter tubing of some sort, to bring pressure to bear on the edge should work. I suppose you could use a half-round & flat other side ******* file would work, also.
TexMedium
Kutztown,pa
A tubing cutter with a blade for copper will make short work of Sch.40 PVC, without reaching the wire inside. It WILL leave a raised burr, just like with copper, though. Easy enough to remove, which should be done if there is any possibile need in the future to pull more wire.
Zeke
Yeah, the little cutters don't work but a full sized one will do it handily. But, as mentioned, the small cutter will establish a straight cut line. So will masking tape.
kaffine
Henderson, NV
Attach pull string to the wire then backpull them a little bit. Try to push some extra pull sting in the conduit past where you need to cut. Then you don't need to worry about damaging the wire.
ycgoat
S.E. Va
I would do extra work to pull the wire back first with a rope or string tied to the cable end that way the pull string gets nicked instead of the power conductors
BreeStephany
Oregon
For anything under 1-1/2", I have a ratcheting PVC cutter that I use to deeply score the PVC and then just snap it. For anything larger than 1-1/2", I have a PVC cable saw. I try to deeply score and then snap the remaining thin layer if there are conductors to prevent any damage to the conductors.
Generally not a practice I do too often, as most of the time its quicker and easier to tie a pull string to the existing conductors and yank them out or to just yank the conductors, modify the conduit and then vacuum in a pull string.
Just my two cents.
