Cutting RR track...
Printer Mike
Eatonton, Georgia
A friend is giving me a piece of RR track with one end that is rough/uneven.
The only tool I can think of to cut it, that I have, is an angle grinder.
Would this work?
gmwelder86
Oakdale , ca
If your handy with a cutting torch, angle grinder would work, band saw. Basically anything that will cut metal. Hell if you had the time a hacksaw would work.
RVDan
North America
My cousins told me they just cut it with an abrasive cutoff wheel when they lay it.
My piece of track is brand new :)
GRX
MD
It is fairly mild steel if I remember correctly. What is the piece of rail to be used for? Just curious.
koditten
Midland, Michigan
A portable band saw will do it easily. You will have to turn over the track and cut from the bottom and meet with the first cut. The througt(sp?) on the saw is too shallow to do it with one pass.
KO
BWS
Mnts of Va
I'd gas axe it....being the lazy type.
If using a saw,flip it over and start on bttm....work twds top.BW
CARS
New Ulm, MN
I cut a section with a chop saw. The top of the rail was harder than the rest of it. I would guess from heat and pressure.
truckin23
S F Bay Area , CA
I cut these with a band saw
spy604
New rail wont be a problem to cut. Used rail is a whole different story. The top surface work-hardens after years of use, and become super hard.
