Cutting Sandwiched Aluminum Sheet
Tool_Freek
I have a sheet of material that consists of
aluminum skins separated by a plastic core layer (unknown compound) between them. The aluminum skins are 0.028” thick and overall sheet is 0.23” thick. Having obtained this material from a salvage yard, I know nothing more about it.
Before investing in a special (nonferrous) 7-1/4” circular saw blade for my Skilsaw 77 worm drive, has anyone ever successfully circular saw cut sheet material of a similar construction before? If so, what blade did you use? Did the plastic core layer melt and cause problems? Did it tend to lift/peel the trailing aluminum skin (top) in the cut? Perhaps this material can only be sheared?
gimpyrobb
Cincinnati
I have not cut what you are planning on cutting, but I would test cut a foot or so section with what you currently have.
I have cut 1/4 aluminum with my circular and it didn't do too bad, I was impressed.
Use hearing and eye protection!
y'sguy
Tulsa, Oklahoma
I have similar materials, and I have been able to cut them with several passes of a utility knife.
I have also cut them on my band saw and table saw. however, this will sometimes leave a ragged edge from the plastic. But, you can easily dress this off with a light sanding.
kerrynzl
Tauranga, New Zealand
Straight cuts can be done with a knife/ box cutter [cut both sides] then snapped over an edge.
If the material is cool it snaps easy.
You can also use a router.
The edges clean up with a flap disc nicely [don't lean on it too much, be gentle]
PCustoms
VT
I'd cut that with a regular wood blade without a second of hesitation
Fine tooth, wear good glasses and hearing protection. It will be loud and make a lot of slivers, but cut fine. Use a blade wax if you have it (Irish spring works too)
mike93lx
Richmond, VA
I bet stuff that thin between layers of plastic won't be that loud. Either way, PPE FTW
Beerhippie
Far NE Oregon
I cut aluminum plate up to 1/2" with my Skilsaw and a carbide wood blade all the time.
I worry with something like that that the blade might just snag and rip the **** out of it. Have you tried scissors? Big shop shears would seem to be dandy.
Firebrick43
West central Indiana
Wabash National trailers is in town and they have trailers made of duraplate.
Its similar but made with 80k galvanized steel instead of aluminum and I have cut tons of it to line buildings and even one wall in my basement.
a 7-1/4 saw with a 24 tooth carbide wood blade cuts it just fine. Its loud and you want to wear long sleeves, eye glasses and a safety face shield but it cuts decent.
T
Tool_Freek
My thanks to everyone for your advice. It appears cutting aluminum with a circular saw and a carbide tipped wood cutting blade is worth a try. Seems odd though, afterall you eventually dull such a blade just cutting wood.
Beerhippie
Far NE Oregon
After quite a long while with modern carbide blades.
Whatever you do, don't try the old trick for cutting sheet metal with a circular saw--reversing the blade. That works with an old school blade, but with a modern blade... picking the carbide chips out of your arms and legs gets tedious after a while.
