Cutting stainless with plywood inside?
isaac338
Halifax, NS, Canada
I went to an auction the other day and bought a whole bunch of stainless ****. One of the items was a workbench with a stainless top - I junked the bench (no room for it) and I'd like to cut a wedge out of the top and assemble it into a corner kind of thing on a bench I already have.
When I bought it I didn't know the top was formed around a plywood core and had planned to cut it with a grinder or something, but now that I realize the plywood is there, what's the best way to cut through the whole assembly? A jigsaw with a metal blade?
Any ideas? Cheers
911mike
michigan
I had to cut a sink hole on my top and used a jig was. It took 5 blades !! My advice is cut slow to keep the heat down. You need a fine tooth blade and this heats up the plywood pretty quickly. Tape the top surface of the stainless other wise it will scratch like crazy.
JimVonBaden
Northern Virginia
Cut it from the wood side; that will leave a much neater finish on the SS. Also, depending on the thickness of the SS, you can use a metal blade in a circular saw, it will help you make a straighter cut. I have terrible luck with a jig saw and very straight lines.
Jim :cool:
ddawg16
S. California
Like Jim said, cutting it from the wood side will leave a cleaner cut.
If you don't have a metal cutting blade for your cirular saw, I would try the sawzal with a really wide blade. I have a couple of blades that are really wide....makes it easier to make straigter cuts.
Joe Reed
Cordova TN
Assuming the stainless is only on the top and not the bottom, how about cutting *almost* through the plywood on the bottom with a normal wood cutting blade on the circular saw...then do the final cut with whatever method you want to use on the steel.
Lippyp
Shropshire, UK
Run a grinder with a thin cutting disk through the stainless, if needs be make two cuts and remove a small strip and then just cut the plywood core with a wood saw, not really rocket science and easy enough to do with the tools you've got!
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Depending on the thickness of the stainless, you may have to cut the stainless with a cutoff wheel then go back and cut the rest of the way through with a circular saw. Sand it all to finish.
