I've got a large piece of steel to cut, and am looking for some new ideas. The piece in question is roughly 4' square and arches with a thickness that varies from 4 to 8" depending on where exactly you measure across the arch. I need to cut about 1' off the overall height. The cut needs to be fairly clean, but not perfect. I can clean it up with a grinder once I get it cut.
I have a wide selection of saws/ grinders/ torch, etc. My torch is not big enough to do it in a single pass. I've contemplated trying to make multiple passes with the torch, but that's going to be slow and use a lot of fuel. I've had a couple of folks recommend either a gas powered saw like they use to cut concrete or an oxygen lance. I don't know if there are blades out there for those cutoff saws that are designed for metal like this. Oxygen lance looks like a good plan, but I don't have one and don't know anyone that does. I'm willing to buy one if the price isn't too high, but all the welding suppliers are closed today so I can't get prices. If I have to rent a saw/ buy a tool to do this I'd like to stay under $200.
Ideas?
Ideas?
I misread it. I thought it said 4" square, not 4' square
