Cutting Tool Steel
Kin Creed
Minneapolis, MN
So I needed to cut down a T40 Torx bit to create a super stubby drive bit to get to a transmission pan bolt. I sort of knew this, but a hacksaw and/or a metal cutting blade in a jigsaw did next to nothing in terms of cutting the bit down. But using a small cutoff wheel in Dremel type rotary tool zipped through it pretty fast and clean.
So, am I correct to say that hacksaws and typical metal cutting blades are for mild steel, and when you get into tool steel/hardened steel you need something different? I don't mind using a cutoff wheel, I just don't like it when they explode shrapnel occasionally.
QwikKotaTx
Seabrook, TX
There are some who say using a rotary tool and generating too much heat can ruin the bits heat treatment or if it were a knife blade etc but for what you are doing it's probably fine.
rlitman
Long Island
There's that, and there's also the fact that the bit is hardest at the tip, so cutting off the tip will leave you something softer. Still not a big deal for the most part though.
matt_i
Get the woven cutoff wheels for the dremel. The other non-woven ones are junk and will explode as you mention.
MattT
You're half right. A decent saw and blade will cut tool steel not problem. They won't cut hardened tool steel though.
