Cutting torch cart.
vdotmatrix
Northern Virginia
I found a hand truck on craigslist for $10 and cut it down to a size for my bottles. I am goin to MIG this.
I have a mock up before I tack it up tomorrow using a piece of PVC.
What could I use to hold these together while I tack it up? Metal tape, long enough to tack one tube on far side?
Mocking it up in place lets me align it better to visualize it. Clamping to a welding table might result in a hidden weird angle after I weld it.
lightly tack on one side and bend and tack on the other?
Any ideas?
RyanE
Golden, BC
You might try some pieces of angle and cradle and clamp each of the two main tube joints to get some tacks on them. It should cause the third tube to align itself and tack it too.
Yep. Came here to say the same.
I've used angle iron "splints" with hose clamps (or even electrical tape works) to square up all kinds of pipe/tube/round stock before tacking.
The Cobbler
I would probably use short pcs of angle clamped with vice grips or clamps to tack it in place , or just lay it flat on a table and hold the pcs by hand & tack . use a straight edge to check/align the other axis
Beerhippie
Far NE Oregon
SOP for ****-welding pipe--around here, anyway.
I really like the design of @lilredex 's cart! Very narrow so it easily goes through doors and tight spots.
BigMike782
The only down side to magnets is that if you get too close it will throw the arc all over.
NUTTSGT
Northern Central Ohio
I would have left it full height. Once you tip it back, you'll be bending over to move it around.
Or get taller bottles.
But yes, angle and clamps.
I might even try to take a piece of the old tube, slit it and use it for sleeves with a few plug welds.
V
vdotmatrix
Northern Virginia
Everything worked out, except for the horrible MIG welds … turns out, the hose was pinched….. more to weld!
Recoveryman
Southern indiana
Vdotmatrix: I agree with LopezBart on not using pneumatic tires. Years ago, when I built my cart, luckily I happened to have a pair of hard rubber wheels with big roller bearings. My shop dollys (two) with pneumatic tires are always flat when I need them. So glad my torch cart has hard rubber wheels ( they were originally on a platform scales). Once every 25 years, I grease the bearings.
Recoveryman
V
vdotmatrix
Northern Virginia
I cut the support from the middle tube and welded the side tubes first, then Aligned the middle tube. It turned out OK....Paint hides everything! I had to replace a section of rusty tube....Paint hides everything.
