cutting zip-ties
solitaire
Whats the best tool to cut zip-ties nice and flush so you dont leave a nasty edge that will slice your hand? Flush cuts? Zip-tie cutters? What do you guys prefer?
89GLH
Westminster, MD
Theres a 90° cutter for zip ties? Thought it was common sense not to cut it sharp? If you do, don't impale yourself on it. If you do, post about it here.
x3 on the side cutters.
Dustin Crawford
If you buy the good nylon not cheap plastic zip ties you can put a set of square ended dikes straight down to the head and 1/4 turn the zip tie end right off. After you are done there is nothing protruding from the head at all. :beer:
MAD
Western MA
I have generally found end nippers to be better than side cutters for flush trimming the tag ends from zip ties.
Biomed
Minnesota
I use side cutters however I have found that if you apply slight pressure on the end of the zip-tie when cutting the cut end seems to withdraw into the zip-tie. (If that makes sense. :))
I worked at a few manufacturing places that had zip-tie cutters like this:
Seems to me the side cutters worked just as well.
dittle fart around
Vancouver, Washington, USA
Worked at a switchboard panel shop and we had tie wrap guns. Been using them for years the type I used cost about 200 bucks. You can get cheaper ones. They tighten the wrap and cut them flush never a chunk hanging out. When the welders on the shipyard cut my temporary cable runs down I used dykes to trim the ties, it left hundreds of sharp edges to cut your hands on.
View media item 12099
Stick
Alaska
I use a zip tie installer. Tighten the zip tie with it, and then twist it 1/4 turn while tightening it some more, and it's cut nice and flush.
T&B WT1-TB and T&B WT2-TB, around $30/ea.
It also helps to use good zip ties, like T&B or Panduit and not the cheapest ones you can get your hands on.
Edit: Beaten like a red-headed stepchild.
DOUGD
+1 on a large pair of nail clippers (the flat ones not the curved).
ishiboo
Oshkosh, WI
i use the small flush cutters like a xuron 170
I use a cheaper generic version of the same thing for cutting my ties. I pull them out a bit as I cut, and as the previous poster said it falls back in so it's recessed.
I tried the Harbor Freight wire tie gun, it does not work... can't grip the tie at all and the cutting function was useless. I like HF but it's definitely not one of usable tools.
BlindViper
York, PA
I use a pair of wire cutters I modified. Normally the cutters have a bevel on the bottom. I ground the bevel off so the cutting edge is exposed. So when used to cut the zip tie its flush.
earlthegoat2
SE GA
When I was a marine technician we used a lot of zip ties and had to make sure we cut them nice and flush so customers would not come back complaining with a hole in their hand. (I got caught by the sharp end of a zip tie cut off once and I probably needed stitches)
Anyway, we all had a product made by none other than Snap On.
Here they are.
http://buy1.snapon.com/catalog/item...group_ID=20118&store=snapon-store&dir=catalog
Any of the SNap On electronics cutters will work though. THe bigger ones can be handier.
Spendy buggers but since we used them all the time they were more than worth it. Dont use them for general wire cutting though like you would with normal side cutters. They are made for thin copper wire which cuts easily. Their jaws come to fine points unlilke normal side cutters which have a nice broad point and a flat edge against which the cutting is done.
These are also handy because they are spring loaded. Nice when you need to cut something in a tight spot and cannot muster the mobility to open the plier.
t100
using a professional tie wrap gun isn't just for cutting the tabs flush, the main reason is to cut the tie wraps at a specific tightness, consistently.
the Panduit gun is used mainly by aviation and racing mechanics, just to make sure the zip ties are tight, but not over tightened to pinch the wiring insulation. same way a torque wrench used by automotive techs.
kissmeimgerman
NY
Have to use flush cutters, I am in broadcast/it engineering - we have a few of those tie wrap guns and they just get in the way or don't fit in tight spaces. Cutters I can use for more than just cutting the zip tie. My co-workers don't use flush cutters, reaching into a rack with sharp zip tie ends is not fun.
rlitman
Long Island
http://buy1.snapon.com/catalog/item...group_ID=20118&store=snapon-store&dir=catalog. . .
If you think that is spendy, you should check out Lindstrom:
http://www.amazon.com/dp/B0058EDC1M/?tag=atomicindus08-20
Flush cutters are the BEST tool for this job. If you twist off, you're weakening the tooth in the tie (even if you use ties with a metal tooth), and there's a better chance that the tie will fall off. Dykes leave that dangerous piece behind.
bert.
australia
hard to explain but i just use regular side cutters.put one jaw on the tail to be cut above the locking tooth. and the other jaw against the back of the locking part then squezze and it will shear the tail off dead flush
only thing is you need to use decent side cutters with minimal wear in the pivot
