I am upgrading welders and my bottle, swapping from a 20 LB to a 150. If I have a big job I usually do it at work that size gets me by at home on the weekends.
Here is your answer.
For most MIG proccess you will set the flowgauge at about 20CFH. That means you are using 20CFH.
Therefore, a 60 cubic foot tank will allow roughly 3 hours of trigger on time. A 120CF would be about 6 hours. Reality is you will see more gas usage than that simple math, but it shouldn't be by much.
EDIT- I see you said pounds in reference to cylinder size. Are you asking about 100% CO2?
If you are, my above answer is wrong. I don't know how straight CO2 usage is.?
I always insert this when welding cylinders come up: Be sure to check your fittings with a soapy water solution when installing a new tank - your gas will last longer!!
I always take a soap bottle with me to check the valve to cylinder threads also got bit in the hiney on one that was leaking picked up on a Wensday was empty Saturday when I went to use it and of course the supplier was closed !!! Have had a couple tanks from them leak .
O Yea +3 on what Jack said the cost to fill it around here was only 3 dollars more than the 40 i used to have !!!
Last week a buddy wanted me to get him a tank, a 20. Gas delivery guy came carrying it in and I said that's just dumb get me a 40 if you have one(he did). In my mind my buddy'll probably end up with a 125. Which my gas co let's us trade up tanks for full purchase price for larger ones so it's not a big deal.
