I need to install a D-ILTCOA light and have a oddball idea. What's a D-ILTCOA light you ask? "Damn, I Left The Compressor On Again" light. Despite leaving myself notes on the shop light switch and making frequent (after welding) 'return to the shop to look for smoke' trips, I still continue to leave the damn compressor on. Since I usually don't go out to the workshop from late Sunday to early the next Saturday, the compressor is being left to cycle continuously as it bleeds down all week.
I've investigated all sorts of scenarios for using current sensing relays, timers and auxiliary pressure switches to accomplish what I want, but I think this latest idea might be the ticket.
A quick detour...in the not too distant future, my work shop will be significantly rearranged to accommodate a small milling machine. For lack of a better option, this new mill (Jet JMD-18) will be located, just about in front of the air compressor (Husky 220v, 60 gal). I'll extend the compressor water drain to make it accessible, but the on/off pressure switch will be awkward to reach. Sure I could relocate it, but it still won't help me with adding a D-ILTCOA light.
So, I'm thinking I'll add a 2 pole disconnect switch in a convenient location between the electric service panel and the compressor. I'll leave the compressor on/off pressure switch in the ON position, and use the new disconnect to control the compressor. I don't recall where I got it or why, but I've got a 110v LED loading dock signal light that I'll power with one hot leg of the disconnect switch and I'll run a new neutral wire back to the electric service panel. The new LED light will be mounted on the exterior of the workshop facing the main house. After dark, it will be very noticeable when lit.
The idea is that when I turn on the compressor via the new disconnect switch, the LED D-ILTCOA light will also light up, and it will stay lit whether the compressor is running or at pressure and idle.
Does this sound like an OK idea?
Another reason for using the LED loading dock light. I'm adding a 110v 'on demand' water pump at the workshop to provide Mrs. Imagineer an easier means of using the 4 barrels of stored rainwater on her garden. The LED loading dock light has 2 lights, red and green. I'll use one for the compressor, and the other will be the "D-YLTWPOA" light. (Dear, You Left The Water Pump On Again).
