I hate to say it, but a lot is going to depend on what type of material you plan on working with and what you're going to be building
Are we talking about cabinets with shelves, built-ins, etc that require sheet goods or shelves out of 2 x 4's, furniture out of solid hardwoods or what?
More and more people are using 'track saws' and once you buy into the system - you can buy an adapter for your router
Is it easier/more accurate to move a router over a sheet of plywood or to try to push the sheet of ply over a table saw?
Personally, I make most of my dados with a router. I own a decent dado stack for my table saw, but the router will cut a cleaner bottom, hands down. I have a Festool track saw (I would suggest you look at Makita) with one of my routers dedicated (permanently mounted) in the router adapter. I know the center of the router bit is exactly 1" offset from the edge of the track. Makes it real easy to set up and cut.
Dozerhand - you are using the wrong router bit if you're getting loose joints with 3/4" ply. The problem is -
ply isn't 3/4". They make undersized bits specifically for this purpose. A 3/4" ply bit is actually 23/32's (instead of 24/32's) and I usually get a great fit
I really like Whiteside bits - this one is for 1/4" shank, they also make them in 1/2":
https://www.amazon.com/gp/product/B000K2C68W/?tag=atomicindus08-20
