Dan Mig 140 keeps bird nesting with 30 wire
ng8264723
Oakham MA
I have had this old beast for years and it has worked well. It seems to weld heavier metal better than sheet metal. I have a little 110 welder from Italy that welds sheet metal very well. This welder tends to bird nest. The tension is not adjusted by a thumb screw it has a heavy piece of sprung steel with 4 settings. To be honest it is kind of primitive. I was thinking of retrofitting it with a more elaborate tension system. No matter what I do it clogs. The little 110 welder does not. I cannot get it to stop. I am 54 now and have had it since I was 18-20. It's sad but I am at a loss. We have tried everything. Now torch (with a new liner). I have adjusted it so it does beautiful springs on a piece of wood. I have loosened it so it I cannot hold it with my fingers
kerrynzl
Tauranga, New Zealand
I had an Italian MIG that use to "Flywheel" the spool with stop start welding [and birdsnest]. I put 4 x pieces of foam behind the spool to create some friction.
Then I sold it ,and bought a spare gun and rollers for my other MIG
Daveyclimber
Montana
Some things to check. Spool tension as mentioned previously, damaged gun liner or associated components or rusty film on drive rollers or the wire.
Spareparts
Lansing Ks.
I had the same problem with a Lincoln 180, but I did carry in on my service truck and it do that, corrected the problem with a 2" piece of webbing ( cloth type ) screwed to the back of the cabinet a little above the centerline of the spool and layed over the top of the spool hanging down the front with a loop on the end, placed a piece of 3/4" round rod in the loop for weight, never had a problem after that.
manac
CT
New tip?
Check the out feed from the roller. If the gap is too large it will lead to bird nesting.
Cut the wire at the roller and pull it through the liner, make sure the friction isn’t too high.
bb29510
my miller mig 140 doesnt like 30 wire, it like 20 wire, it has to do with a clean ground
N
ng8264723
Oakham MA
I have a new liner and gun actually. The flywheel idea is interesting. I will post a pic of the strange tensioner
N
ng8264723
Oakham MA
So here is the tensioner. There is a lot of space between the roller and the outlet
manac
CT
Well that’s an interesting design. My Lincoln starts supporting the wire less than 1/16” from the rollers.
It’s always been like this, and worked. Have you always used 0.030” wire? 0.035 would resist birds nesting a little better.
Try lowering the tension on the rollers. Miller’s mig guide says the drive should slip when the wire is stopped, but should drive with the wire while deflecting off of something.
With that setup if the wire stops it’s going to bird nest if it doesn’t slip.
kaymccampbell
Upstate New York
Any chance the wire is dirty? Corroded? Oversprayed? Have you tried cutting yourself a length of wire and running it through the liner and head by hand?
sqznby
Coastal NC
Very cool, love seeing older style machines and how they were designed.
That guide definitely needs to be closer to the drive wheel and have the liner come out just a bit further.
What size wire are you trying to feed? Try using one size larger tip.
N
ng8264723
Oakham MA
I figured it out! The torch enters from the right and apparently was not centered in the aluminum. It looks fine but when I took it apart there was arcing and a bad ground! I moved it cleaned everything and put it together and it is mint now!
