hbus1300
Installing a Max Jax lift in my garage that has a 4" slab that meets the published requirements. Opted to use the Optional Epoxy Grip Anchor Bolt Kit as I wanted the extra bit of security and will be removing/installing the lift and thought I might work the wedge style standard anchor loose.
Reviewed the Wej-IT specs for their PS2-58 anchor and it states the minimum hole depth should be 6-1/4". I went so far to email wej-it to confirm and got this response.
"The PS2-58 requires a 6-1/4" min hole depth. If your slab is only 4", these anchors should not be used.
Regards,
David
David Garfield
Executive Vice President
Mechanical Plastics Corp."
I then contacted MaxJax/Dannmar support and got this response.
"Arturo Montes- Hello Jeremy, the minimum requirement is 4 inches"
There was a little more to that exchange, but they stood by 4" thick regardless of the floor thickness.
For those who have used the Power-sert PS2-58 anchors. Do they work with 4" thick concrete as Dannmar states?
Regards,
David
David Garfield
