Dead blow exploded.
NoahG
Detroit, MI
Well, got a solid 5 years out of this 22oz slimline. Picked it up in 2014 on Epstein’s day. Garland branded but sure looks like a Trusty-Cook. Who knows when it was actually made. I was smacking some wood into place when suddenly pieces went flying. Interesting, the internal canister was cast in on a angle (may be hard to see in the photo but it’s definitely off center)
barrysuperhawk
Middle of Illinois
I've "killed" several Harbor Freight DB hammers, BANG! BANG! THUMP psssshhhhhhh (the shot going across the floor). Like most things the old school black ones seems like they lasted a lot longer than the newer orange ones but the last of the black ones died a couple of years ago so now all I have is orange ones
matt_i
That looks like the exact internal construction of an orange snapon I got about 26 years ago and did the same thing with plastic flying everywhere.
bwringer
Indianapolis
Yep, they're a consumable item. NBD.
Thanks for the pics, and hey -- at least the furshlugginer thing didn't explode and send shot BBs all over the place.
INSP380
Cleveland, Ohio
I have a very large SO dead blow, kinda looks like something you’d ring a bell with..�� It was split to death all over, even down the handle. SO took forever, but they replaced it. Must be common...
Steve
finn
The UP, God's country
My HF exploded by itself sitting in the toolbox drawer in an unheated garage.
No operator intervention requi.
Same thing happened to the air hose on my HF planishing hammer.
Apparently HF plastic isn’t designed for cold climates
dr_clyde
Holland, MI
I've blown up a hammer or two in cold weather. It happens.
Now I buy dead blow hammers from the tool truck and they hand me a new one if it gets busted.
bobcatdan
Kaukauna,WI
I had three orange snap on ball pein deadblows I bought 20 years years ago. About five years ago, one by one they went poff. Turn them in for warranty and now I have the new red ones. My green matco deadblows from the same era are still going strong.
rlitman
Long Island
Dead blow dead.
-- Dave
I saw that post and your avatar and all I can think is that it's "pining for the fjords".
I've broken a few HF dead blows through heavy use. The only dead blow I've had disintegrate in a drawer was a Snap On.
Plastic doesn't last forever.
senlow
Wheat Ridge, Colorado
'E's not pinin'! 'E's passed on! This hammer is no more! He has ceased to be! 'E's expired and gone to meet 'is maker! 'E's a stiff! Bereft of life, 'e rests in peace! If you hadn't nailed 'im to the perch 'e'd be pushing up the daisies! 'Is metabolic processes are now 'istory! 'E's off the twig! 'E's kicked the bucket, 'e's shuffled off 'is mortal coil, run down the curtain and joined the bleedin' choir invisible!! THIS IS AN EX-HAMMER!!
lis2323
I had the same experience with the DB hammer my Snap-on guy sold me.
Newt
+1 on the Snap On dead blows. Temperature change seems to be the killer from what I've seen. I go through about 1 a year. They keep replacing them though.
Djosbun
My avatar? That's Ava. She used to like me until Toby came along, who I rescued. Toby is now her boyfriend and Toby hates my guts.
-- Dave
PureLeaf
They should do a recycling policy. Give them the internal metal hammer, and let them recast the plastic around it again.
racingtadpole
The far side of crazy.. but sometimes Australia
I left a small snap on dead blow in a box of tools in storage for several years (I live in Aus so no issues with them freezing) It literally disintegrated to powder. When I attempted to warranty it the dealer refused to believe it was a snap on it had powdered so bad there was no identity marks that were legible on it.
i4ni
That looks like a brand they use to make that i think they called Compo-thane.
Material looks indentical. They get about so old and explode.
Rickster
SE PA
OK, please school me on the difference between these plastic dead blow hammers and the rawhide mallot.
Rickster
SE PA
I have two rawhide mallets that I use that give you the ability hit without damage and deliver a solid hit with very little bounce back. You can beat the hell out of these and either shave back worn edges with a side cutter or just replace the rawhide slug.
lis2323
I’ve had the same happen with a SO composite handle ball pein.
MattT
Rawhide don't bounce much but definitely bounce more than deadblows. Really noticeable when seating work on parallels in a machine vise. One smack and it's done with a deadblow.
Southern83
North Carolina
We tape the heads at work if we're working inside a system (valve, turbine etc). We mainly use a dead blow sledge hammer. Have see several bust but the tape saved us from a mess.
Honda guy
North Carolina
My SnapOn 32 oz deadblows last about 8 years. I think I'm on my fourth one now. No problem getting it warrantied.
On the other hand, my Mac deadblows get kind of sticky and start crumbling apart. Not covered under warranty.
overkill19
I have a very large SO dead blow, kinda looks like something you’d ring a bell with.. It was split to death all over, even down the handle. SO took forever, but they replaced it. Must be common...
Steve
I have two SO ones in a bucket! SO won’t replace so now I just show everyone the comes in my shop how great the warranty is!
MattT
Who told you they're not covered? I just checked a price list and it shows the deadblows being lifetime.
rlitman
Long Island
That’s not SO. That’s a crappy driver. Give them a call, and they will honor their warranty.
welder4956
Birmingham, AL USA
The plastic used in dead blow hammers is an industrial grade of urethane. Urethanes can decompose in the presence of a warm humid or moist environment, a process called hydrolysis. The urethane will lose all of its strength and crack/crumble. In a dry, low humidity environment, urethane will last much longer.
My take on this is that I clearly need to air condition my garage, if for no other reason than to protect my dead dead blow hammer.
davethorik
Norka, Ohio
mr.lemons
UK
Gedore also make non exploding deablows. Made in Austria.
MattT
I love my Lixie and Nupla dead blows, but you bring em up on here and nothing but crickets, because your average GJ member thinks there are only 2 dead blow options, HF and trusty cook. :rolleyes:
Let 'em keep ignoring Nupla. Stuff nobody's heard of goes on clearance;)
But yeah you're right, it's hf or TC with this crowd. And don't go overpaying for a TC rebrand with a lifetime warranty:lol_hitti
Don't get me started on pb Swiss either, because it's perfectly fine to overpay if tools come from Switzerland. But not the USA.
Did you click the link to that "100% Made in Switzerland" hammer? Handle looks more like CA than CH.......................
