Dead Fridge?
Bruce Amacker
Cleveland, Ohio
Hey Guys:
My dorm fridge at the shop quit working and I just want to verify it's dead before tossing it. It was working fine up until the other day when it went warm. The compressor is warm to the touch (120+) and I unplugged it and let it cool down a few hours. I plugged it back in and the compressor got warm again and something clicks like a thermal breaker. It's dead, right? Ditch it, right? I put custom paint on the door so I want to make sure before it goes in the trash.
Thanks!
Dagny
Northern Wi.
A new current relay will make noise suppco makes a handy replacement solid state device. most refrigeration guys will have several in their truck.
bonneyman
Desert SW
If it's gotten hot several times the comp has been heat stressed. The motor windings insulation will start to decompose and eventually fail. But before that the oil will start to carbonize and start varnishing the bearings.
Do all you can to keep it from overheating. Keeping the cond coil clean is a big help.
rust in the eye
Chicagoland
Yeah, I've repaired a whole bunch of these little fridges thrown to the curb. The little gizmo that plugs onto the side of the compressor is the failure on almost every one of them. Google the # on it, they are dirt cheap and easy peasy to replace.
Make sure the condenser coil is clean too.
