truck
Okay, so I built the lofts in the shop see my build thread here: shop build and I've had a dilemma on how I was going to get heavy or bulky items up there. I didn't want to build a huge stair case taking valuable room in the shop. I thought about building a pallet dock platform for the lift and using it as an elevator. I may have been able to make that work but Bimmer's thread here got me thinking, "a cheap forklift would work and be mega useful". So searched CL with nothing under $2k. Finally last month I came across an ad "Air Compressors, Forkifts, Going out of Business". In it he had a large 12K Yale forklift for $4000, several IR Rotary compressors and one short line inside that said "TCM forklift needs work $800". I though I would go check it out. Turns out it is a propane TCM FCG25N6 rated at 5000#s with a triple mast that went up 240", standard up/down, tilt, and shuttle shift (side to side), service and parts manuals, and new forks. It was dirty, a little hard to start and ran a little rough and has small hydraulic leak and didn't include the propane tank. I told him I would have to think about it since it needed work and asked what else he had. He showed me around and I left to think about it. After a couple of days and a little research I went back to him with a package deal offer for $600.
Here is what I got, I think I did okay:
- the forklift as described above w/1247 hrs.
- a 38" shop floor fan
- industrial shelving (3x 14' uprights 2' deep, with many 8' cross bars)
- a panel saw (minus the saw)
- a bunch of standard steel shelving w/12", 18" & 24" shelves
- a 4'x8' white board and a 4'x5' white board
- a heavy duty 2 drawer filing cabinet
- an Okidata color laser printer
- a buttload of scrap steel (smaller stuff but good for skids plates on the jeep or smaller projects)
Local gas supply sold me a standard 33# steel propane tank full for $150. I ended up having to pay $100 for a rollback to deliver the forklift after 2 tries with 2 different trailers that couldn't hack it. Inside one of the manuals had written 1205.5hrs: checked rod bearings, honed cylinders, new rings, cut/seat/lapped valves, cleaned/adjusted points, adjusted carb, new muffler. So if it has been gone through fairly recently, hopefully it is a timing of propane feed issue not something serious.
Truck
Truck
] and see if it holds vac........if not, exchange fuel locks or a rebuild kit is easy..........course check for spark and that there is no obstructions in the intake..........let us know how you make out..........
