krusty the clown
Member Emeritus
Bottom line: I will drive home and it will be pulling to the right and vibrating. I hate dealerships. Even Sears could throw it on the rack and see if the alignment is in spec without having to follow some stupid flow chart. I'd be royally pissed if I actually had to pay an hour of labor for this visit.
here's the real problem, the manufacturers are holding the flame to the dealers for warranty expense. they have to have a sizable reserve to cover warranty expenses as required by federal law. IF they can reduce warranty cost, next year they can pull some of that money out and get big fat bonuses. not following the flow chart and properly documenting it will cause the mfr to kick back the claim. the problem you have is that the tech can't properly test drive it due to the snow, so he could do the alignment and maybe fix it ( just setting an alignment by the numbers doesn't always fix a pull) but most likely it will come back and he will have to do it for free. i know it ***** but it's because of the mfrs policies not the dealer or the tech.
The sad part is there is some legitimate issues with tires. We get low profile tires in on soft compounds that have sat a while and they flat spot. Sometimes within 48 hours you can see it has started while watching the tire spin on a balancer. We set the tire pressure to max and then drive the car at around 65mph and you can actually feel the vibration start to fade after around 10 miles when the tire warms up and forces out the flat spots. The sad part is a 35, 40 or even 50 series tire on a 18-20 inch wheel will start to do this. I used to think flatspotting was something that happened when a car sat for a year or so but with today's compounds it's becoming more frequent where I work.
