I bought a ridgid 223 reamer. It has a lot of blades so it works like a file and leave alot of copper shaving. Having to cleaning out the tubing have me worried.
If any burrs is missed, it dislodge as a hair of copper when flaring and make an imprint across the flare or cause some galling. Sometimes the outer edge gets jaggedly if not deburred enough.
After alot of prep I was able to produce what I think is usable, however the tube in the first picture was not prepped enough. I finally found out alot of burrs hidden when I use a "V" blade on the cutter across the tubing. That needs to be paired, then reamed until no little hair comes off.
So is this the wrong reamer to use, should I use the "pen" type deburring tool?
Do you also ream the outside of the tubing?
I have not done a 1/4" which is common for liquid line yet, I don't know if the pen debur blade will fit in there
Thanks
Thanks
