Decent 3/8" drive impact sockets
ArtisanFarms
Phelps, NY
I'm looking for some decent 3/8" drive shallow and deep sockets in both metric and inch. Which brands today are decent, hold up OK and relatively thin wall for impact sockets? I will be using them mostly with my M18 3/8 drive impact.
BlakeTheCarGuy
Roanoke Virginia
I’d look at Capri or Tekton. Really can’t be beat for the money in my opinion. I’ve got the Capri 3/8 deep set and use them in a professional setting they do excellent they don’t wear out near as fast as some other brands have for me.
qqzj
Most of the common brands you see are decent. In fact, it is hard to find anything with a brand name that is not decent.
Professional Tool User
BC
Impact sockets is one of those tools where the brand doesn't really matter. You have to really beat on an impact socket to break it. I've only broken one of my made in China impact sockets from Canadian Tire in 2 years of hard use. The only reason I would spend more is if a set has a better selection of sizes. I would go for one of those made in Taiwan sets with no size skips that come under brand names like Sunex. Wall thickness for impact sockets is usually around the same as a chrome equivalent.
BC
I think the Taiwan tools are better than the chicoms
Not always. Overall quality control is more important. At Harbor Freight, COO isn't a guaranty of quality. They don't pay extra for quality control. If you pay attention, you'll see quite a few made in Taiwan tools with visual defects on the shelves.
turbodave
IL/WI
I went with this Gearwrench set and have been happy with them
https://www.tractorsupply.com/tsc/product/gearwrench-44-pc-3-8-in-drive-impactsockset-84916n
What I liked is that the small ones taper down and are fairly thin walled for a good length. I see that also on many other brands are similar like Milwaukee and Tekton etc..
What I was trying to stay away from was a set like these Husky ones that are a thick socket with just a slight taper at the end on the smaller sizes.
GeoBruin
If you want thin wall, check out the Gray Pneumatic Duo impact sockets. They're very sleek. I use them with my 3/8 drive stubby and they're perfect. At those power levels, they'll last for ever.
webscrounger
Midwest
Depends on your budget and need. You don't really need a high dollar name name brand set if it's for occasional use. A lot of affordable mid-tier brands available as mentioned before. Look at the size range you need and for size skips. Set contents vary. Some sets may have 8mm - 22mm, others maybe 10mm - 19mm, some may skip a size. Sunex and Grey Pneumatic DUO master sets are not the cheapest but are my preference. Both are thin-walled (IMO) and used with impacts and hand-wrenched. Sunex sets are more affordable of the two and have a good warranty. The master sets have regular and deep sockets, no skips and a pretty broad size 3/8" range in 3/8" drive ( 8- 22mm and 5/16" - 1"). Swivels as well. Over the years I've collected a drawer full of ******* sockets, big-name and no-name, they've all worked OK.
CS454
Not Snap On. Box store variety is fine.
Signed,
- Someone who owns SO Impacts.
tyyost
Tunkhannock, PA
Sunex. Get their 3/8" master set and you will never want for another 3/8" impact. Shallow, deep, swivel, torx, etorx, and extensions. The only thing I had to add was a 1/2" to 3/8" adapter so I could use all those lovely sockets on my big gun.
Second this, I had some Pittsburg deep 3/8 and a set of Kobalt USA metric 3/8 and I bought the master set and have impressed. The swivels are super handy, all the sockets are good and the selection with no skips is prefect. The only thing it didn’t have were the new style nano shallow sockets like Astro makes, so I did add a set of those.
M635_Guy
NC
I went with the Sunex master set, and I've been happy with it. But I have plenty of wrenchy buddies who do a lot more than I do and have had zero issues with their Pittsburgh sets. In retrospect, I would probably have done better to get the inexpensive option from HF.
For impact sockets, I think it's far harder to make a mistake.
sk farmer
nd
Just so I don’t fall into that trap, what’s wrong with S-o impacts. I do know they are $$$$$$$$.
other than they are 3-10x the cost of many other impact sockets nothing.
there are lots of places where snap-on may be a good or better choice. the common consensus is that they are not that much better and, in many cases, not as good as other brands. i have heard many say other brands are superior.
i have several brands from no name to snap-on including, cman, sk hf, ir, and some i am forgetting i am sure, in 1/4 to 1 inch drive. other than a bottom of the barrel 1/2 drive metric set that all cracked i have had good experiences with all of them.
Rinspeed
NY
I really like SO tools and have a bunch but most of the time they are way over-priced for what you get.
CS454
Answered your own question, ridiculous money for general purpose sockets. I've had to warranty my SO sockets more than my Expert (Facom) sockets as well, SO leaves the female end of the socket a bit too soft for my liking and they end up falling off the gun from wear.
jpaw
Just don't have your hand near them during use.
The difference between the cheap ones and the higher end ones is the cheap ones break and the expensive ones will usually crack.
Cheap ones on an impact don't scare me but leaning on a cheater pipe I want a quality socket
Rinspeed
NY
My Aircat is rated at 1,300 ft-lb and I've been trying to break a HF impact for five years, so far no luck. I live in the rust belt and it's rather tough on fasteners.
BC
You sound like you think the cheap ones will explode. The one cheap impact socket I did manage to break cracked.
CJM8515
Sunex, i also have grey pneumatic duo sockets I love as well. the master 3/8 sunex set is worth every penny. the grey pneumatic are thin walled impact rated sockets and very good to have. I also will use chrome sockets on my milwaukee stubby m12 impacts, but they dont make the kinda power a 3/8 or 1/2 air gun will. been doing it for years with no issues
thefraze_1020
Burlington, WA
My work (a municipality) recently bought a set of Blackhawk impact sockets. I'm impressed. But they are 1/2" drive.
Also, I have an older set of Wright impact sockets that I love. I would give Wright a look.
jpaw
Never said they would explode. Just stated that the cheaper ones tend to break instead of crack which is more dangerous.
As a professional mechanic I have broken my fair share of tools and hurt myself doing so. That said I have both sets of hf deep impact sockets at home because they fit my budget for home.
DemoFly
Port Orchard, WA
I like the quality of my Sunex sockets but the legends on them are horrible. A tiny stamp and tiny laser etching that wears off basically immediately. The drive end isn't chamfered either which is something I don't like.
if I could do it over again I'd probably still buy the Sunex sockets since there's nothing as good and also CR-MO in the price range. I'm never going to buy a CR-V impact socket. I don't care what anyone says.
Chumly
Alpine, CA
I'm using Tekton and they warranty them without question, as for this posting and prior. It's an impact and you beat the hell out of it. Also note that adaptation happens and good tool companies adapt. A Tekton impact wore out on the 3/8's drive end and the one I got has more time on it and it looks good as new as of this point. They changed tooling and improved their product in that particular model. Impacts are soft by nature and I guess they were a taaaad too soft and hardened up a bit more on the drive end. Socket end on both looked good, it was just the earlier driven-end that wore and that's the thicker part of the socket (mass).
I'm also a SO buyer and that's where you get into a deep debate that's larger than this one thread and it's all about the person on the truck. That's a truck-tool thread that can even be splayed 50 different ways besides the tool in question, itself. All of the trucks can have good or bad people on it. When you buy a lifetime warranty tool that you pay for "Made in America", then you expect it and sadly bad truck owners will put a stink on every bit of that promise.
Don't buy a truck tool if you don't trust the person, not the tool. That person could go away and you run into the next truck guy that you never bought from them so they don't wanna take the risk on you in order to warranty the tool from the prior owner that moved to another route. I don't understand that still unless they're thinking we're all truck-bed thieves.
Anyway, they all talk, focus on the tool, and an impact socket set will eventually wear out. I'd rather build experience with this on a lower cost set just to see how much time vs money spent on that one tool over which brand. Going straight to a Truck Brand is a fool's errand and I tell that to the boys the same as anyone here. That truck step is DANGEROUS!
TL/DR: Tekton/Gearwrench/Something in the USA or attempting to be full USA.
Bbknucks
Any impact socket will do just fine. They get the snot beat out of them but usually hold up well regardless of brand. Only benefit of the expensive ones off the truck are they come to you to warranty them out when you go ham with a hammer on em or something. So that justifies it to me cause I abuse them. I buy alot of SO but hard to recommend theirs based on the ridiculous $$$ unless you just wanna flex on your shop mates
