Decent steering wheel/balncer puller set?
NOTABLAZER
Lately I've been going through my tools and upgrading/replacing some of the stuff I have,and I just got to the puller drawer. This is the one I have now,it was given to me many years ago:
http://www.harborfreight.com/46-piece-bolt-puller-set-37824.html
It works fine,but over the years many of the pieces have walked away from the set,so I'd like to replace it. Can anyone recommend a similar set that's a decent price,or should I just get another one from HF?
Seanbev24
Lynnwood, Wa
For that price, if the only problem with the set is pieces got lost over time, I vote for buying the same one. Hell, buy 2 so you have spare parts.
I bought the same set 6 months ago. I figured if I had problems with it, I'd get something nicer. So far my only complaint is I wish it had a better tray/case.
Hiball
Missery
Id say if you had good luck with your Current HF Puller buy Another one, I cant see how $14 bucks is gonna hurt you either way. I picked up a Snap on set that looked real similar off ebay for $50 bucks shipped, Ebay is flooded with those pullers most of the Time FYI.
rsanter
visalia ca
I have a snap on puller like that (only better) that I can part with
when I have tried to use the HF version for pulling something really tight like a gear that have stripped. the snap on version does not
for steering wheels they are fine
bob
stock z/28
I balance crankshafts, and I install and pull a lot of balancers, and in my opinion the Snap On is by far the best.
I have a lot of pullers from a lot companies and none hold up as well as the Snap Ons.
mrholeshot
MEMBER EMERITUS
I dont like the old style pullers like Snap-On has. I use one made by Fluidamper I bought 15 years ago that looks like the one pictured. Removing and installing mega dollar balancers in expensive crankshafts can be a critical move especially in big block chevys. I like these because you can remove and install without a cone in the end of the crank. As much pressure as it takes on BBC engines to remove it's a crank saver. I'll never go back to a old style puller. This one isn't exact but bearing pull in both directions.
http://www.summitracing.com/parts/PRO-66514/
Big Bad Jon
If you don't use it very much. This one will be fine for steering wheel use. Heck for the price you could get three of them. I am always concerned about using anything HF that when it fails could cause you harm. That means for me pullers, breaker bars, prybars, ect. are a no go. YMMV
stock z/28
Typically on the aftermarket balancers I hone the bore of the balancer to give the specified interference fit with crank, as supplied by the balancer manufacturer.
For the last few years I have been using a hydraulic puller/installer I made similar to one that ABS offers. It takes most of the work out, especially installing them. Some balancers require heating in an oven to a specified temp..
Some are just a pain.
In regard to typical pullers s I said I would take the snap on over any other I have used.
