Decision: Set of super thin open end wrenches, or super thin adjustable?
NoahG
Detroit, MI
The Toolguyd post about those Engineer Thin Jaw adjustable wrenches spurred me to make this thread.
Quite often I run into the need for a super thin wrench for 9/16" and 11/16" jam nuts. While I'm tempted to just buy those two sizes, it seems much more cost effective to just buy a full set. However I so rarely use the other sizes that for a similar amount of money I could get a thin jaw adjustable and always be covered no matter the size, plus it would be much easier to store and could easily live in my gig bag.
So, if you were in my situation, and had a need for super thin wrenches just often enough to warrant their purchase, would you get a set, or an adjustable? I know a set guarantees best fit but I worry about how strong stamped steel is.
sberry
Brethren, Michigan
No reason to buy them all if you only need a couple but we find an occasional use for them. I have simply ground off a China to make them but have a set from Sears that used o come with every big tool set. They are actually called tappet wrenches. Nut sure if they would be on the shelf in a big Sears store or if they even make them.
monomach
Illinois
Quite often I run into the need for a super thin wrench for 9/16" and 11/16" nuts. While I'm tempted to just buy those two sizes, it seems much more cost effective to just buy a full set. However I so rarely use the other sizes that for a similar amount of money I could get a thin jaw adjustable and always be covered no matter the size, plus it would be much easier to store and could easily live in my gig bag.
You mean like tappet wrenches or do you really mean the stamped ones?
If tappet wrenches, I'd just get a set of used ones. Better fit than an adjustable. They're not stamped out, though; they're forged. At least mine are.
SantaAna12
Yes....forged please.
Some nice old V-series sets on Ebay.
NOS. Niiiiiiiiice!
N
NoahG
Detroit, MI
What is the thickness of the Tappet wrenches? The lovely Craftsman website has no product details.
N
NoahG
Detroit, MI
Here's a picture of my primary foe. They're 9/16" jam nuts used on chandeliers, table lamps, and other electrical fixtures. They're 1/8" thick, so I don't know if a Tappet wrench will fit. The kit I've been considering is this one
OutsideMachinist
Norfolk, VA
The tappet wrenches are definitely more than 1/8'' thick. They may still work dont know honestly. The set you linked would probably be fine since it is low torque.
Ign
Butte Peak ND
Hmm, the red pouch is reminiscent of the set by V8 Tools that I have from tool warehouse (I think). My V8's have been fine but don't use them often. Don't remember what I paid, it's been at least 6 or 7 years
kelpaso1
MEMBER EMERITUS
New Brunswick
I would just buy a couple cheap wrenches in the size you need from a flea market or pawn shop and grind them down to the thinness you need.
wild cowboy
Birmingham
Tronyadorable
If it's an Apex company you will NOT have any problem with it.
justme-
Boston suburbs
I've never seen a cone wrench (that I am aware of) but unless you get a junk stamped steel "wrench" nothing will be as thin as those 1/8" lighting nuts.
Tappet wrenches are about half thickness and are from the days when you actually had to adjust the tappets in the engine valvetrain which are now generally not needed due to hydraulic self adjusting lifters.
GirchyGirchy
Central Indiana
Cone nuts are that thin. They're made for adjusting the cup-and-cone ball bearings on bicycle wheel hubs.
They are stamped steel but not junk, as long as you're using them for their intended purpose or something similar...did you see what the OP wants to use them on? FFS, those don't need a lot of torque.
