Deck Design Tools
moparfreak
Milwaukee, WI
So I've begun some design work on a deck on the back of my house I plan to install targeting next spring, and as many decks are its a bit of an odd shape, as it has to conform to the back of our house and the backyard.
I want to draw this up in detail and get a good material list set as I get ready for the build, and figured I could use one of the numerous online deck design tools. To my dismay, after trying 4 or 5 of them they are all so flawed. If you need any type of shape different from a basic square you're screwed. There is no flexibility whatsoever to merge shapes, combine levels, etc.
I've tried the Lowe's, Menards, Azek/Timbertech, Decks.com, all with the same basic results. Anyone have any luck or experience with this type of thing.
Yes, I've actually used Sketchup for a number of my woodworking projects in the past and that is my go to backup plan, but as infinitely customizable Sketchup is, it's also a lot more time investment. If I have to do it I'll do it but figured maybe it's worth an ask to find a program out there.
gahrajmahal
Cincinnati, Ohio
Hi moparfreak, sadly that was my experience with it too. I also attempted to use sketch up and found it to be extremely time consuming. I resorted to good old pen and paper. Order several deck building books from your library, check with your township planning commission too for permit requirements. Good luck.
cowboy73
southern Indiana
Try drawing up your plans on graph paper. Make each square equal to a 4 inches. Might have to tape a few sheets together to get a large enough plan. My dad designed his house that way.
M
moparfreak
Milwaukee, WI
I think I'm going to go ahead w/ sketchup anyways. It's proven quite useful for showing my wife what it'll look like, proportions, etc. Sitting down and going through a big set of graph sheets with my scribbles on it showing 2D views is probably going to cause marital problems. :shocking:
mikehaugen
Northern IL
A little off-topic, but does anyone have any insight about the amount of data-usage the web-based sketchup consumes? I live in the boonies with no option for high speed internet except the 4g plan that I have. It is reasonably fast, but data hungry browsing (videos) consume my month allowance pretty quickly.
Sent from my SM-G930V using The Garage Journal mobile app
mikeb27
NW Indiana
I used SketchUp for my deck design and build last year. Was able to use the 3D images for permit as well, and color-coded boards to help my ordering process.
M
moparfreak
Milwaukee, WI
That looks fantastic! Very good inspiration. I'm pretty much 100% gonna go this route, so will get started shortly. It'll give me a chance / opportunity to play around with some of the more architectural capabilities (changing views & coloring schemes, etc).
gahrajmahal
Cincinnati, Ohio
Mikeb27, question? Did you use the free version or the paid one? Your plans look really great. It was a few years ago I was messing with it and they could have improved it since then.
