Deck footer off by 3 inches... options???
enceejay
CNy
Building an attached deck and of course screwed part of it up. One of my concrete footers (12 inch sono tube) is 3 inches too wide. My deck will have 6x6 posts holding up a tripled 2x10 beam. I've attached a picture to illustrate my problem. Can I drill a hole through the post bracket to accommodate the bolt in the concrete and still be okay? The bracket will still be on the footer, just at the edge of it. HELP!!!
8tsC0qR
E
enceejay
CNy
Your situation isn't uncommon, I think you'll be okay bolting down the bracket as shown.
The problem is very little of the beam is on the 6x6 post, probably only an inch or so. Are you saying I should be okay to drill a new hole for the bolt in the concrete and just sliding the bracket over to where I need it?
Chuckster in NJ
Hunterdon County NJ
NO PROBLEM! It may not be centered but the post is sitting on the pier...... Mission accomplished!
**** UPDATE! I posted this ^ reply after looking at the OPs illustration THEN he mentioned (at the same time I was typing) that only 1” of the post would be sitting on the pier after I hit the "post button" and then went to work........ This is a definite violation because 75-100% of the post must be on the pier. Do it right and do it over because when you sell the house a "knowledgeable" home inspector will pick up on this violation.
Natty Bumppo
Savoy, MA
You're saying that if you DON'T MOVE the post base over you only have 1" of contact? Then yes, drill your hole and move the post base over a few inches so you'll have more than 1" of the beam sitting on the 6x6. The post is still solidly on the pier...no problem.
GMCGarage
8tsC0qR
How much load is on the post? It could cause a overstress in the soil bearing, might lead to some settling more than anticipated.
nadogail
Coronado, CA
Maybe you can weld a plate to the post bracket and drill a hole in it to accommodate the discrepancy.
ddawg16
S. California
While I think you can make it work structurally, If you are anything like me, the OCD would kick in and I would look at it for the next 20 years and it would bug the **** out of me.
Personally, I'd dig up the post and do it over.
BD1
north side
I think it's fine. As for securing the post, add a angle clip on the exposed concrete side and anchor to concrete. Then lag screw or drill 6x6 and through bolt
Falcon67
Merkel, TX
Agree that if the 6x6 lands on the footer you're good. Your OCD will never let it go, but support wise it should be good 'nuff.
doctordirt
If this is for the beam supporting the joists, adjust the other posts, so they are all on the sonos tube and cantilever the joists.
