redman43
As the title states, what are your preferences? Are there any advantages or disadvantages to either that I haven't thought of?
Personally, I just realized I have both. Space is at a bit of a premium in my box (and no a larger box is most definitely not an option
), so I find myself having to decide whether to keep the dedicated nut-drivers that are currently occupying the entire space inside one of the small drawers in my HF tool cart, or take them out, find a home for them on the bench, and replace them with the significantly smaller footprint of a 1/4" (spinner???) handle and use it with my 1/4" sockets.
If it matters, the nut-drivers are the HF 7pc metric and 7pc SAE set, full range of sizes from 5 to 11mm and 3/16" to 1/2". My Craftsman 1/4" socket set has a wider range in both SAE and metric as well as a few deep-well, not to mention the ability to use the larger 3/8" sockets using an adapter.
Ideas, thoughts, ramblings...
That said, as Mrholeshot said, they usually have hollow stems, so you can pull nuts off overly-long bolts that you'd have to hunt for your small set of deep sockets for.
