jloehlein
So, I have a section of 42" deep pallet rack in my shop. I'd like to be able to store things under the first tier, which is ~30" off the ground, more efficiently. Stuff like jack stands, extra boxes of shop towels, safety glasses, etc. I'd like a couple drawers underneath it so I can utilize the full depth.
I briefly looked for pre-built things that could meet my needs, but didn't really find anything that deep. I then started looking at drawer slides to build something and they are way too expensive. At that point, I drafted up a system that I think would work in SketchUp. Would love feedback on it.
Here's how it works:
The base is basically a couple pieces of angle iron supported by 1" square tube legs that would be bolted to the ground. There are bearings attached to the base that support the drawer at the front. The drawer is an angle iron frame that I could put plywood sides/bottom in. There are sets of bearings supporting that back of the drawer that the angle iron rides between. Here are some pictures of what I mean and a link to the SketchUp file.
The few thoughts I've had:
1) Capacity: I'd want to limit drawer travel so ~6" stayed on the rails - then I've got ~36" past the front bearings and ~6" behind them when opened making a 6:1 lever. I think (8) 608 bearings (rated @300lbs each) could easily support most things in the top drawer (even 100lbs all the way at the front of the drawer would only exert 600lbs of force when fully opened...am I thinking about that right?)
2) Side-to-side play: I'd leave 1/16"-1/8" between the drawer sides and the rails. I'm not too worried about these being precise feeling, so I think this would be fine? Maybe if it was I could throw in some UHMW to limit side to side movement.
I think I could build these, including a drawer on wheels on the bottom that just rolled on the floor, for like $50-$60, which isn't too bad. Please poke holes in this design before I cut up a bunch of metal and spend time building it!
