Deep dive into induction cooktops, magnetic coupling, power use.
Denwood
Thunder Bay, Ontario, Canada
Six months back, I bought (what I now know is a crappy pan for use on induction), but labeled as induction compatible. I spent about three months testing, built a few dedicated test rigs, and got Home Assistant up and running to gather data for the tests. I was also pretty curious about how induction worked in the first place...so down the rabbit hole. Anyone who follows my garage thread here on the journal knows I have rabbit holeitis in the worst way.
As an experiment, I used ChatGPT to help script and design a shot list for the original video. It was the worst performing video I've ever published. I picked up my bruised ego and re-edited doing thing my way. If you're not into the video, here's a summary.
1. The fridge magnet test doesn't work if you're looking for what works well on induction.
2. Matching the hob size to the pot base can halve the time taken to boil a liter/quart of water. A 1.9L Tramontina Signature pot did the best (on the smallest induction hob!!), 2:56 to boil a quart.
3. Cast iron coupled the best and also pulled the highest wattage from the cooktop.
4. Using highest power on the induction cooktop does not equate to the same actual watts used on different pots. There are huge differences.
I hope you guys find this useful, interesting or even mildly entertaining :)
nadogail
Coronado, CA
We have been using a General Electric induction cooktop since 2017, if it ever fails it will be replaced by another Induction Cooktop.
We had to replace our 40 year old stainless Farberware pots with induction compatible modern stainless.
ChefRex
Following, I really need a new stove but I want dumb, the problems I hear of make me want a stove dumber than the average 10YO.
I have considered an induction hot plate type deal on the side.
Just_Steve
Dutchess County, NY
There is nothing smart about an induction cooktop except it's ability to regulate the heat better than gas or electric.
My sister paid $1700 for one of those things. I absolutely hate it. Doesn't matter if I'm using Great-Grandma Potter's cast iron Dutch Oven, or a $3.99 second-hand "All Clad" from Goodwill, it does not maintain a consistent temperature. Absolute piece of garbage - burners can't seem to make up their minds if they want to be "on" or "off".
I would drag the thing out into the street and wait for a scrap metal guy to pick it up.
D
Denwood
That was interesting. Thanks for posting.
Those are kindest words I've opened the browser to in the last few days..honestly. There was a lot about induction that had me curious when I started down the rabbit hole.
Just be careful on those words "induction compatible"! There really should be a standard with cast iron at 10, and everything else measured as a standard against it. I think that's what got me going on this whole thing...compatible just means you'll get heat out of it, but it doesn't tell you how much.
Count me as an induction cooktop fan, been using one for the last five years since kitchen remodeling. I will never use anything else if at all possible. Thanks for the video.
I'm not a foody, but I do love making the Sunday Finn pancakes (super thin, like crepes) and for that the cast iron skillet (which I've sanded/polished) and induction at about power 6 for our cooktop is about perfect heat right across the pan face for these babies :)
Having done the Kitchen reno I wanted induction pretty much for the clean cooktop and efficiency. They are around 90%, so top of the heap that way. I also have the exhaust fan automated to the cooktop (it's an ECM fan, 0-10V control) so the fan ramps with the power use on the cooktop. The fact that the power delivery is pretty much constant (except at very low settings) makes the automation work smoothly too.
Wood and Coal stoves are very dumb.
Nice in power outages though...
I'm not an expert on the electronics of the hob, but I do think it cuts power depending on the coupling. Now if that's just inherent in the physics, or part of the control circuit...that I don't know.
I am sure there are differences in control. The one I tested on is a pretty average IKEA 30" unit. Because I do have the 240V Aeotec switch in there, I can monitor power live. On 1 or 2 power level it may cycle a bit, but after that the power is pretty much steady and a function of which power level you're at, and what kind of pot is on the element. The max I saw on the large burner was 3700 watts with the cast iron, and that stayed very steady during the test.
We're quite happy with our induction unit; I wish I'd spent the money to get a double oven and 5th burner though...
I really was not happy about the Missus insisting on a wall oven and a cook top, but I'm quite glad we went that way. The only hassle really was running two 240V circuits instead of just using the existing feed for a range. We're not massive foodies by any stretch so I think the record for use has been 3 pots going at once. With a 30", you kind of run out of room anyway...
loganb
Omaha, NE
Hum....I've been considering a move to induction....this and my brother taunting on how fast he can boil water on his may push me farther towards it
D
Denwood
Just pick the right pot!
We have a 120V single burner job out at camp and it takes forever to boil water. We use it to boil water for corn on the cob and my wife has questioned me every time on why it's taking so long. I used to blame the burner, but now I know that it's 100% the pot. It passed the fridge magnet test (on a few pieces of our old pre-induction cookware delegated for camp use) so I figured great...but as I learned in the video, that fridge magnet test doesn't really tell you much. I was buying a new set of cookware (I'm not), I'd like take a look at the Tramontina Signature stuff as you can get a 8 to 10 piece set without spending crazy $$$. I bought the 1.9 and 2.8L as one offs for the test, but going back I could have gotten a full set for not much more.
^ I wouldn't know watts from my elbow. I don't really care about the "sciency" part of it, I just want a stove that does what I want it to, when I want it to. That range at my mom's fails on both counts: it does not maintain constant temperature - you can see the "element" going on/off/on/off/on/off while cooking. Ergo: NOT constant.
Appreciate the video. Maybe I'll take a pot magnet up to Mom's next time and check out the crappy pans my sister buys. Like her "Pyrex" cookware that she uses on that glass-top range. Could very well be that the problem is the pans, but that doesn't account for that on/off/on/off nonsense.
Just_Steve
Dutchess County, NY
That does not sound like an induction cooktop, sounds like a regular electric with a glass top , there are no elements to see on induction.
Milton Shaw
We are on our second induction hot plate now. First one was burned bad by turning the stove top on under it and cooking the bottom of it. Love them they are the fastest heating type for cooking and warming stuff. We did take the knobs off those two element controls under it. At $120 to $150 they are a super bargain. The pot we were using turned the element on while stiring the pot, which is why we took the off.
BillK
Beautiful Southern Maryland
I dont understand how it could be better than gas as far as regulating the heat ? With gas you can actually see the flame and know what you are getting. And it doesnt require special cookware.
Just_Steve
Dutchess County, NY
i have used gas before, was never in the habit of stooping down to look at the flame, I know what "I'm getting" by the numbers. I'll admit there might be a small learning curve but it's quit intuitive.
Dumber than lumber
I bought an induction heater tool off of Amazon. It was not the cheapest one for what that is worth.
Anyway, it is fascinating what can be done with it. Not something that I use very often, but when needed there is no substitute.
