deep magnetic sockets
mbshop
visalia ca
I'm finding that I need some deep magnetic sockets. mostly 1/4 drive.
but they need to accommodate long studs, etc that the nut goes on.
I have regular magnetic sockets. any that are easily gotten ? thanks,
shockwave
Marietta,ga
I have the matco adv/sunex set they are great but don't have the best clearance for studded bolts with the spring has to be pushed down
You might look at snap on has magnetic adapters that fit in like the smallest extensions
And the grey pneumatic and sunex offer 5-15mm
Where truck brands offer limited sizes like 7,8,10,12,13,14 it really depends on sizes you need
KnurledNut
n/a
problem is that I only need a few sockets.
Here are the individual part numbers.
That might help in your search.
Magnetic Deep Length, Metric Sizes
905MDG | 1/4" Drive x 5mm Deep Length Magnetic Impact
906MDG | 1/4" Drive x 6mm Deep Length Magnetic Impact
907MDG | 1/4" Drive x 7mm Deep Length Magnetic Impact
908MDG | 1/4" Drive x 8mm Deep Length Magnetic Impact
909MDG | 1/4" Drive x 9mm Deep Length Magnetic Impact
910MDG | 1/4" Drive x 10mm Deep Length Magnetic Impact
911MDG | 1/4" Drive x 11mm Deep Length Magnetic Impact
912MDG | 1/4" Drive x 12mm Deep Length Magnetic Impact
913MDG | 1/4" Drive x 13mm Deep Length Magnetic Impact
914MDG | 1/4" Drive x 14mm Deep Length Magnetic Impact
915MDG | 1/4" Drive x 15mm Deep Length Magnetic Impact
955MDG | 1/4" Drive x 5.5mm Deep Length Magnetic Impact
Magnetic Deep Length, Fractional Sizes
906DG | 1/4" Drive x 3/16" Deep Length Magnetic Impact
907DG | 1/4" Drive x 7/32" Deep Length Magnetic Impact
908DG | 1/4" Drive x 1/4" Deep Length Magnetic Impact
909DG | 1/4" Drive x 9/32" Deep Length Magnetic Impact
910DG | 1/4" Drive x 5/16" Deep Length Magnetic Impact
911DG | 1/4" Drive x 11/32" Deep Length Magnetic Impact
912DG | 1/4" Drive x 3/8" Deep Length Magnetic Impact
914DG | 1/4" Drive x 7/16" Deep Length Magnetic Impact
916DG | 1/4" Drive x 1/2" Deep Length Magnetic Impact
mbshop
visalia ca
anyone know how deep it is with the magnet pushed all the way in ?
specifically looking in the area of 6, 8 and 10 mm. thanks,
KnurledNut
n/a
They all have a bolt clearance depth of 24mm.
The OAL of the sockets is 50mm.
gdocktor3
Connecticut
What about magnetic extensions? I have a few cheaper extensions from Sunex and Gearwrench. Or the magnetic inserts as mentioned.
Mr_B
Reading
I made my own adaptors for sockets I already had, used soft springs and magnets at varying lengths and 3 diameters spring/magnet to work across 8 to 19mm sizes. simply epoxied magnet either end of spring and slip one in socket when needed, works quite well and didn't cost $10 plus easy do 1 off for special scenario .
Adam.C
When I was young a good mechanic taught me to simply use a dab of wheel bearing grease in my sockets. Nice thing about that is, you can stick a nut and a washer to any socket an it isn't attracted to anything else.
PelicanPines
I have done that... it works. Now I just stick a magnet on the side of the socket. If I'm using a ratchet... no problems from spinning too fast.
mbshop
visalia ca
Great ideas guys ! Thanks so much. Yes, most of my career I used grease. Or a dab of gasgacinch. But kinda messy at times and I just thought I would step it up a bit. I may try making my own as I like doing stuff like that. Again, thanks !
Mr_B
Reading
^ do a trial one with a spring from likes of a pen and some 1mm or 2mm thick round neodymium magnets (easy get diameters of 6 to 15mm) The ratchet end magnet needs either catch socket bottom or ratchet drive end, I sized them to ratchet drive end.
On final ones I gave magnet ends couple plastidip coats as bit of protection. Has worked well in most scenarios once get use to best way use them and perhaps remove after nut/bolt started or when removing fastener fit on in socket after fastener already loosened most of it's thread run .
Other cheap tricks is bluetak or piece of paper to jam fastener in socket or spanner .
