Davey4000
When adding a subpanel I know you are supposed to isolate the ground and neutral in the subpanel. My question is what exactly is the “electrical” definition of an isolated ground and neutral in the subpanel?
In the main panel the grounding bar is bonded to the box. Neutrals (white) and grounds (green) are terminated to this grounding bar. Okay, now I run 4 wires from the main panel to the subpanel. The white wire goes to the neutral lug in the subpanel and the green wire goes to the box. The neutral lug and the box are not bonded (no ground strap or screw from the neutral lugs to the box). Now my question is this…since the white and green originate from the same place in the main panel does this not defeat the effort to isolate them in the subpanel? In the subpanel you can put an Ohm meter across the neutral lug and the box and get a reading, as opposed to being open. Is this still considered being “isolated”?
