shoot summ
- Joined
- Jun 8, 2010
- Messages
- 2,949
This is one of those learn as you go things...
I bought some great ornamental gates about a year ago, the work on them is incredible. It started a whole side yard renovation that is finally getting close to complete. In my wisdom I decided to change the way the gates were originally hung in favor of some great ball bearing hinges. They previously used a "pin" at the bottom, and a brass strap at the top.
I did some research on the steel to use for the posts. I wanted something in 2.5" as I plan to wrap the posts in wood to look like 6x6. I thought 3/16" wall was enough but now that I have the gates hung there is a fair amount of deflection that allows the gates to "sag". I can probably use some sort of connection to a post less than 4' away to resolve this, and then hide it somehow in the fence. What I wondered though is if filling the 2.5" steel post with a high PSI concrete, and embedding a 1/2 rod in it would help, or if it is a waste of time?
The posts, and fence panels on each side will match what I did on this one:
