buzz
This winter I'm looking to solve some moisture issues I keep having and am wondering which is the most efficient way to do so.
Bit of background:
1100 sq ft garage attached to house, R50 in attic, R24 walls (2x4 roxul, 2" SM), 3x "R16" doors (1-3/4" thick insulated door, doubt the R16 claimed) and electric heat. Located in Winnipeg where winter temps are down in the -30 C range.
I would like to keep the garage at 10 C and turn it up when I go out to work in it. It houses 2 daily drivers and my race car, so can't avoid the mositure coming in, but want to keep things relatively warm for when I go work in it. The main issue is condensation forming on the garage doors, then dripping down and freezing the door to the floor.
This past year I epoxied the first couple feet of the floor which helped a little with the freezing as the ice seemed to not stick as much as the year before. Still did not solve the problem though. I also had an older dehu running, but it would only pull moisture when temps are above 20 C.
This year looking into the option of either a low temp dehu or putting in an HRV to bring in the dry winter air. Trying to figure out which is the most economical option to go with.
Bit of background:
