Best to include all the information like:
*The temperature increase in the supply or discharge air, compared to the incoming air stream, will vary between 15° – 25° depending on the load the dehumidifier has to take on. However, this does not mean that your home will increase in temperature by 15° – 25°.
The air is mixed with the rest of the air in the home and distributed evenly by utilizing the HVAC ductwork that is already in place. In addition, for every degree that you increase the temperature, the relative humidity will drop an average of 2%. Therefore, the home will typically experience no more than a 2°-4° increase in temperature as long as the dehumidifier control is dialed into a reasonable setpoint (77° and 45% relative humidity is recommended by ASHRAE). Setting the RH% too low (ex: 35%RH) will result in further run time on the unit and additional heat output.
* from the Santa Fe web site.
