Dehumidifier Recommendations
Rowdy Rat
PA
I'm in the final stages of finishing my garage and would like to install a dehumidifier.
I looked at several units that were sized to handle my garage and was leaning toward this unit...
http://www.thermastor.com/Santa-Fe
...until I saw the price which is around $1000.
Is there anyone out there that can recommend a good dehumidifier that they have experience using? I do have some criteria that I need to meet.
The unit needs to be:
- Sized appropriately for my garage (1300 sq/ft with 12 ft walls)
- Quiet
- Reliable
Also would be nice if it could be:
- Located remotely
- Ability to set the humidty level
Any thoughts on this one? Any help or feedback would be greatly appreciated.
Regards,
Stan
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
A heater in the winter and AC in the summer will bring down humidity levels. They keep the area more comfortable for the tools and their owner also. :thumbup:
2LTim
Central Iowa
An air conditioner is just an overgrown dehumifier. And a great selling feature for the better half is that, "It is a much more efficient machine, and will do a better job of keeping the moisture off of all of the nice tools that YOU have given me over the years!"
You can control one with a humidistat, but a thermostat is less expensive and works well.
Have fun with it,
Tim
R
Rowdy Rat
PA
Thanks for the responses guys.
I actually have a garage that is heated and air conditioned and yes, I know that the a/c will do a passable job during the summer when it is running.
I guess my big issue is what to do in the winter when I want to wash the cars inside? I really don't want to keep all that moisture trapped in the garage (for obvious reasons) and turning on the a/c isn't really an option when the temperature is below freezing... I guess that was my primary reason for wanting to use a stand alone dehumidifier.
Any thoughts?
Regards,
Stan
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
A heater as I mentioned before. A dehumidifier won't work well in a cold area anyway.
Dawgfan
Northeast Georgia
Look at the ductless mini-split heat pumps. They have dehumidifier modes. I'm going to put one in our new shop.
I have a Soleus CFM-25E approx. $160. I use it in our travel trailer and in our house when conditions don't call for heat or air conditioning. It works good.
Iron-Iceberg
A-town
There was a thread on here before on removing condensation. One guy if I remember right used a bag full of salt rock hanging over a pan.
Search some old threads.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
In cold or hot weather the regular heating or AC equipment will probably do just fine. For those "tweener" times a small dehumidifier may help. The small dehumidifiers I have had experience with required regularly dumping the catch container. There may be some that have condensate pumps but then you would need a drain to connect to. I also saw a lot of corrosion on the coils after a couple seasons of use.
snorky18
Southeast Tennessee
see
http://www.garagejournal.com/forum/showthread.php?t=17229&showall=1
for previous thread
my opinion copied..
http://www.amazon.com/gp/product/B00009RAVO/?tag=atomicindus08-20
We have this in our basement and love it, been running continuous for longer than I can remember. It's extremely quiet, even on high. Pulls a maximum of ~2.7 Amps, so it's cheap to run as well. The fan runs all the time, but it has different humidity settings and the dehumidifier part kicks on and off as needed
R
Rowdy Rat
PA
see
for previous thread
my opinion copied..
Thanks for the link... I just saw it now as it was the lead topic in that section.
Regards,
Stan
