Dehumidifies?
Jarvis
in
What humidity should a garage be when there are cars stored in it?
J
Jarvis
in
We got mold starting and bought a dehumidifier and it's was 83% and now we keep it 55-60% but had someone tell me it needs to be at 38%. That seems low!
usa#1
If it's a wood framed structure measure the moisture content of the wood studs and joists. You should be able to find some data on acceptable moisture levels for wood on the internet.
abstamaria
Manila
l understand rust stops forming at 60%. Below 40% and you might get wood shrinkage and cracks in leather. Piano manufacturers recommend 55%, so that's a good number.
Andy
LS6 Tommy
Northern NJ
38% is a pipe dream with any store bought dehumidifier, considering the average desert has an RH of 45-50%...
Tommy
J
Jarvis
in
Dehumidifiers is a must! Keeps barn cooler and no mold. I have 72 quart and will fill bucket in 24 hours.
BearsFan315
Portsmouth, VA
just went through this, in the winter it was staying around 40-45%, cold dry winter. then summer hit and was staying around 70-75%. surface rust was popping up on clean metal, and things i was working on. Have a PTAC and keep it on 74F
got a dehumidifier and set it up for 50% left the PTAC as it was 74F after 3 days the humidity stays around 45-55%. and it feels a lot cooler granted the temp is still 74F
I live close to the coast of the Atlantic so moisture is abundant !!
LS6 Tommy
Northern NJ
That sounds pretty high...I just checked and the relative humidity in Phoenix right now is 19%. In Qatar it's about the same.
My numbers may be WAY off. I used numbers from memory that were based on what we experienced on an average of what we see in the US...
Tommy
