I have an air compressor that was sitting in my garage when I moved in.
It has a Quincy X8-55 Compressor, and a Delco 1hp Motor.
The motor has a hard time starting, sits and hums, even with no pressure in the tank... If I disconnect power, rotate the compressor a bit, then re-apply power, it starts right up and runs to the 100 PSI cutoff. turning the compressor is not difficult by hand. I just cannot find any info on this motor to see what starting cap is used etc...
Model is A-8886
Serial K-61
182 frame
Type CS
115/230V
1hp
1725 RPM.
Attached is a pic of the label.
Any info appreciated!
Model is A-8886
Serial K-61
182 frame
Type CS
115/230V
1hp
1725 RPM.
