Wiebster
Hi guys. I just picked up a Delta 15-270 drill press at an auction. The motor won’t spin when first switched on without spinning it by hand. Has a starter box not sure if that’s the problem or if it has just sat for so long. But my main question is on the pulleys. As I look at the parts diagram from Delta it shows a step pulley on the motor and a step pulley on the spindle. Mine has what I think is an original Delta motor with a 2 step pulley, then an idler pulley with 5 steps mounted on a cast iron sliding dovetail, then a 6 step pulley on the spindle. Anyone else have one of these With the idler? The two step motor pulley will only line up with two of the pulley grooves on the idler, either real fast or real slow. I also can’t get the motor to swing close enough to get the belt into another groove. Is it just too short (wrong belt) from motor to idler? I guess my main question is I think I’ll be limited in my speed selection by just running off the small diameter motor pulley. Am I missing something. Thanks
