Rockable
I am in need of a more HD drill press. I routinely drill up to 3/4" holes in flat bar (usually no thicker than 3/8") and use holesaws to cut gauge, speedometer, AC vent holes in sheet metal in my hot rod and custom builds.
Tomorrow, I am going to look at a locally listed Delta 17-925 variable speed press. They say it probably needs a belt. I know the sheaves for this are no longer available, so I will inspect them carefully.
Is this a reasonably heavy duty press for a hobby shop, assuming the pulleys are good? Is it hard to replace the belt? Any other caveats I should be aware of?
Thanks
Thanks
