Delta 70-200 Spindle pulley has up and down movement
jrsavoie
North east Illinois
Delta 70-200 drill press Spindle pulley has up and down movement
The spindle pulley mounted tight has less than, but close to 1/8" play up and down. Along with the spindle sleeve it is mounted to.
The pulley is about the same amount lower than the adjustment pulley pulley.
If you pull the spindle pulley up, it is flush with the adjustment pulley
Any words of wisdom on a Delta 70-200?
https://www.toolpartsdirect.com/delta-70-200-20-drill-press.html
