Delta DP 220 Drill Press Spring
dogzbody1
Long Island, NY
Hi all
My mechanical rebuild or more accurately assembly from parts continues. I'm inspired by the restorations on this site but want to see and hear it run before I get out the paint and brushes.
The drill press has a wound spring on the left side (looking from the front). I'm guessing it is to hold the quill in the "up" position but no matter which way I wind the spring the quill drops to the bottom, is there a trick to installing the spring?
Thanks for any help you can provide.
Best wishes
Steve
topcok88
https://www.garagejournal.com/forum/showthread.php?t=320086
Check out my rebuild thread here. I bought one off eBay due to an indication on the original. I still have the original and it still works. If you can not get it to wind I would guess it already broke. Shouldn’t be too hard to find a replacement. There are plenty of diagrams on OWWM available and Accurate Bearing out of Texas had new bearings available. Good luck!
D
dogzbody1
Long Island, NY
Thanks you both, that is the part, I never would have thought to look on amazon but they have new ones available (2 1/8 inch return spring).
Thanks again!
Steve
