Delta Drill Press-good buy?
Woods_Wanderer
Virginia
I've been on the lookout for a better replacement for my current craftsman drill press with trashed bearings and came across this. Seller says it's a 17" delta on 1phase 120v, no other details given. Would this be a good choice for my metalworking needs?
Can anyone ID the model? Do I need to look out for anything with this model, and can I get parts for it? He's asking $400 for it.
View media item 111347View media item 111348
Packard V8
Spokane, WA
Interesting design of what appears to be a shop-made vise using a Chicom table and an unknown mill vise. Never seen one like that.
However, the photos of the Delta are inconclusive. They don't show enough of the front and the belt guard.
jack vines
tool_scrounge
Southern California
Most likely a Delta rockwell 6+6. They started making them in the mid 1960s and is one of my favorite 15" drill presses. It has 6 speeds and 6" of quill travel. Well built and relatively compact. It is not a 17" drill press as there is no table lift mechanism and the head casting is different. The power switch makes me think it is a later one, maybe late 1970s? $400 seems a little high based on the amount of rust.
Isaiah6113
Oshawa, ON
^ this.
It doesn’t look like a 17 to me either, looks like a 15 head design, in addition to your observations the pipe doesn’t look big enough, the stop collar looks similar to a Rockwell collar I have (pic below). Although, that does look like a 17 base, maybe there’s a bushing in there, a retrofit.
17s usually have a cap that is bolted to the head or table to keep them on the pipe. This machine has the pipe passing through a casting for both.
Thats one heck of a mag starter, sure I’ve had big mag starters on my household stuff, but wow. I get the vibe of a 220/440 3-phase originally in an industrial setting. The plug appears to have been cut off, which is not uncommon when these come out of a work setting. It might have been directly wired into a service box.
The hand feed has two of the handles replaced with those stubby things.
Yes, $400 too much. If it is a Delta, parts are plentiful.
If you are still interested get the seller to send you a pic of the model/serial number tag. Also a pic of the motor tag. If they don’t then you know something is up. While you are at it get him to measure from the centre of the chuck to the pipe. If it’s a 17 it will measure 8.5”. Get a pic of the badge on the front of the machine too. A “peace sign” logo signifies a Rockwell International era machine. Not all bad, but preferably you want one early 70s if so. The serial # will help date it.
Matt
PS this is a Rockwell 15” collar on my 1955 Craftsman
tool_scrounge
Southern California
I totally missed the mag starter with all that clutter in the background. The motor should be single phase due to the capacitor on the motor.
When they swapped the motor to a single phase one, the previous owner could not be bothered to unbolt the three phase motor starter off of the side. This issue, the rust and the hack handles usually is an indicator that machine was " rode hard and put away wet". I would not buy it unless it was a lot cheaper.
subroc
Dover, NH
I wouldn't give $400 for that press.
I called about something similar to that late last year for an absurd price. We get into the back and forth and he comes back with "these things sell for $500." Well, maybe so. After 120 hours of work, $40-$60-$100 worth of bearings, another $50 worth of consumables and any replacement parts needed it might be worth $500. This isn't the $500 one, this is the $75 one.
Needless to say, I didn't get the press.
Anyway, good luck with your decision.
Trapps
The Detroit Zoo
The used DP market has gone completely bat-$#!t crazy. I am both sad and relieved it's not just the metro Detroit area.
To the OP, way too much rust to justify at $400. YMMV.
lafester
Northern CO
I'm not sure whats going on with the delta 15 inch presses. I've seen quite a few pop up around that price and they seem to sell. People must think they are the same as the 17 inch version... they are good dps but not that good.
Of course condition is everything and that one isn't great.
The starter would bring around $150 on ebay so that is something to consider.
