Delta Homecraft Drill Press restoration
dngrmse
Northern NJ
Posting this for my father- he probably got it for like 50 cents or something with his luck. Before and After:
PFSard
Mesa, AZ
Very nice work. Hard to believe the Before and After presses are the same animal.
Mike W.
wow! man you did a good job! did you re-plate that light fixture?
D
dngrmse
Northern NJ
Thanks for the compliments, no re-plating was done on the fixture; It's a thick gauge of brass on top, and solid aluminum on the bottom. A little sanding, some steel wool, with final polishing on a buffer.
jransom
Nice job on the press. I got a little déjà vu when I saw it.
That looks great too! How did you shine up the column? I have a Scotch-Brite wheel I'm considering using on mine but I'm not positive yet. Thanks.
Pavement
Hey could any of you guys with this press tell me what size bolt the thumb screw is that holds the handle in place? Thanks
D
dngrmse
Northern NJ
Hey Bobioz,
They could be twins! Almost anyway. Like the color on it, good choice! Sorry Pavement, I do not have that drill in my possession, so not sue what size that is.
Yes, he does need a new pulley for it, unless he makes sure not to use that top groove.
D
dngrmse
Northern NJ
Thanks nines, he's very happy with it, and the light was probably his favorite part of restoring it.
Bobioz1
Northern il. (For now)
Thanks. I spun the column with all thread, a drill in a vise and a jack stand with an oil soaked rag. Someone on here posted the idea and it worked well. Redneck lathe I think he called it. Just keep moving up in sand paper til you like the shine. It went really quick.
