lazer50
My shop table top drill press is a delta milwaukee home craft.the side tag says Rockwell delta power tool division rockwell m f g.milwaukee Wisconsin.the motor plate reads delta wisconsin model 62-413 hp 1/3. 115v. 1725rpm 60c y. Type c s frame 56 y relay code j-52. It came from a factory years ago and i used it and it worked fine then.i had put it away and not used for several years. I recently built a new shop and brought it back out cleaned all the dust off plugged it in and the motor just hummed.so i tried spinning the chuck by hand and the motor will take off. If it runs awhile it will take off easier with help.but if it set its harder to get started.since then I've had the press apart to paint had the motor off spun the motor with belts off bearings are smooth.checked belt alignment for binding.is this just a worn out motor or maybe a bad capacitor? The drill press is in excellent shape and very well made so iwant to make it operate correctly.i have used it several times and it drills fine once the motor is started.thanks for your input in advance!
