Delta Wood Planer/Jointer
Model A Fan
NW Washington
How much is this thing worth if it works? How hard is it to replace the blade? Are they a good thing to have or is it just a cool thing if you don't do much wood shaping or cutting? Its $150+tax and runs well. 1/2hp motor.
Voi
Western South Dakota
First things first, technically that's "just" a jointer. For some reason they were often referred to as jointer/planers even though they serve slightly different functions in a workshop.
The vintage table saw and (DeWalt) radial arm saw markets have taken a beating in the last 15 years and that has really trickled down to most powered vintage wood working equipment.
The one pictured is missing the guard and didn't come stock with the more desirable art deco style base.
With all that said, I'm guessing that $150 is at the upper end of fair. Maybe somebody else will know more.
Cutters for that tool are easy to get and cheap. There are probably several options for switching to a spiral cutter head. Is replacing an easy job? Not necessarily. You can spend a lot of time adjust blades, infeed and outfeed tables and the fence.
For that reason a lot of people take these vintage jointers and set the depth of cut and leave it once all the other adjustments are made. So it becomes a machine for milling a flat face and straight and perpendicular edge and not much else. Rabbets, bevels and longer jointing runs are done on other machines.
gungatim
west mich
if you don't work with much rough sawn wood, it's not going to be very useful, other than cleaning up edges of sawn boards, although with today's glue-line-rip blades even that isn't needed much. the fence is the old style that tend to flex some along the length but it is certainly still usable. My first jointer was the HF clone of that and worked until I upgraded to the big 8" aircraft carrier. but I do a lot of woodworking and even that sits idle most of the time.
I would value it around $200-250 if you like old Delta WW machines.
ar2stp48
Magnolia, Arkansas
The "BH" ( id plate) identifies it as 1955 vintage. Stand is original Delta. Blades are easy to change and adjust. Any small missing part can likely be found via ebay. The price you gave is low; I agree with another post on $200 to $250. I would quickly pay $200 for it
Model A Fan
NW Washington
After watching some videos and seeing what it is used for, I think I may pass as I just don't see myself getting that involved in woodworking where I need something like that. I think a table saw, router, drill press and miter saw will be all I will need to do what I have in mind over the years. I'd like to build bookshelves, some furniture like hutches or cabinets and useful garage shelving. I just don't foresee this being all that necessary for my goals.
Thank you for the advice and help identifying it. It is cool, and neat how vintage it is, but just not practical for my small garage right now. I think I taxed my space with the lathe I brought home, that honestly was an impulse buy. :/ :dunno::lol_hitti
Jarhead0408
Who knows?
I dunno man. If you are going to do cabinets, you're going to need to be able to true the edges. This would be perfect for that. Add a planer and you're good to go.
I've got roughly the same jointer. It's also a Delta, but a few years older and with the art deco base. They're mighty fine machines. That price is a killer deal. I don't know if you've seen it in person or not, but that machine has a pretty small footprint. It's just heavy. Well, mine is at least, but I've got a heavier base than that one.
Sal Bandini
For truing the occasional edge just make a jointer fence for your router table.
rsanter
visalia ca
The more woodworking you do the more you will want/need a jointer.
Yes it can also Bo used as a planer but not a great one. There is a difference between a planer and a thickness planer.
The more furniture and cabinet type stuff you will be doing the more you may wish you had one.
Go,offer $100 and if you got it for that you got a bargain
Bob
